26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
2d Post Tension (PT) Cable
These is a 2d Post Tension Cable call out and symbols. Below is a list of the files that are used with it. Please let me know if you see something that would make these better.
PT - Post Tension.rfa is the main file. It's the one will use to place your cable. I have 4 Family Types setup in it. It can be easily changed up to do what ever you need.
PT - Force Tag.rfa is the tag that you need to call out the Force on that Cable. There are 2 types setup here. one for Kips Per FT and one for Total Kips.
PT - Text is used to show the height of the cable. PT-text are just symbols you can place them were ever you need them.
PT - Offset End. I made it up so if i need to work around an opening in the slab. It's still in Beta. It will get you around the opening but you are going to have to work for it. I'm hoping to think of a better way to do it later on.
You will also need to add two Parameters to your Shared Parameters. One called FORCE for Discipline Structural and Type of Parameter Force. The other is FORCE PER FOOT for Discipline Structural and Type of Parameter Linear Force.
Product Version: Revit Structure 2013
1531 Downloads
8x48 Hollow Core Precast
Parametric instance of 8"x48" hollow core precast plank.
Product Version: Revit Building 9
5429 Downloads
Arched beam
Arched beam
Fully adjustable beam:
- Rectangular profile (b=..., d=..., b1=0, d1=0)
   OR
- 'I' profile (b=..., d=..., b1=..., d1=...)
- Width (b) & height (d),
- Arch height (Arch_h),
- Material.
4773 Downloads
Bay Window Framing Profile
Reference plane and lines may need some adjustments
1446 Downloads
Double Tee
Double Tee
Double Tee used in precast construction
4.5 Stars from 3 Votes
Product Version: Unknown
6391 Downloads
filigran
filigran
731 Downloads
Free Floor Template from The_Revit_Network
Feel free to use and experiment with our free floor template. If you enjoy our content please see RevitNetwork.com for more.
5 Stars from 2 Votes
714 Downloads
Hollow Core Slab 350
350mm Thick Hollow Core Slab
1 Stars from 1 Votes
Product Version: Revit Structure 2014
5585 Downloads
Hollow Core Slab HCS100
100mm thick Hollow Core Slab
1.5 Stars from 2 Votes
5347 Downloads
Hollow Core Slab HCS300
300mm thick Hollow Core Slab
5272 Downloads
Hollowcore Beam
parametric hollow core beam.
4759 Downloads
Hollowcore Beam
2589 Downloads
Lintel - Wall Hosted
Pre-Cast Wall Lintel for openings, Parametric, Left and Right overhangs, Depth, height AFFL and Material. Opening only for the Lintel, no door/window opening
3.5 Stars from 3 Votes
8162 Downloads
Mr GGs new roof beam
A roof beam
3 Stars from 2 Votes
4327 Downloads
Multy Cell Box Bridge
This is a muly cell auto dimension Box Bridge for road.
In autoset dimension for foundation Raft, end & inner webs as well as deck slab is set as per span, while in MORTH setting one can set these dimensions manually.  For longer length of bridge  repet & align family providing expansion joints. In this case Return walls & approach slabs be off. Provision to off/on for Cut off wall, Raft Key, left & right Return wall & Approach Slab have been provided. Railing of main bridge / on approach can be set indepentely. Number of span is ristricted as total length of bridge may not exceed 30 mtrs. for more length add more bridge. The box type bridge is revised up to date, as this was loaded in 2006 on this site. Lallan Ji Upadhyay. Varanasi.
893 Downloads
Multycell RCC Road Bridge Upgraded
It is a RCC Box Bridge for one to multy spans. Number of spans, Clear span, Clear height , Road width params can be set independentely. Approach slab, Return walls, Cutoff walls, Drop key etc. can be placed/remove at will. In autoset dimension for foundation Raft, end & inner webs as well as deck slab is set as per span, while in MORTH setting one can set these dimensions manually.  For longer length of bridge  repet & align family providing expansion joints. In this case Return walls & approach slabs be off. Provision to off/on for Cut off wall, Raft Key, left & right Return wall & Approach Slab have been provided. Railing of main bridge / on approach can be set indepentely. Number of span is ristricted as total length of bridge may not exceed 30 mtrs. for more length add more bridge. The box type bridge is revised up to date, as this was loaded in 2006 on this site. Lallan Ji Upadhyay. Varanasi.
Product Version: Revit Structure 2018
443 Downloads
Parametric L Shaped Beam
Precast concrete. Parametric L shaped beam.
3473 Downloads
Precast floor element TTP
Product Version: Revit Structure 2011
2023 Downloads
Ribbed slab Section with Reinf.
ribbed slab section & reinforcement , permanent hollow block used
4.5 Stars from 5 Votes
3691 Downloads
Runway Beam - Dam cau truc
Dầm cầu trục.
1663 Downloads
snowflake tower
snowflake tower
3d modeling for te famouse snowflake tower
1161 Downloads
Spaceframe - Space Frame - Gian khong gian
2438 Downloads
Stahlton ribs concrete precast beams Revit 2019
http://stahlton.co.nz/products/rib-infill/
480 Downloads
Truss Anchor Concrete Wall Connector
this is a face based family (Truss Anchor for Concrete walls). Use the vertical face to place it (i.e. the vertical side of the concrete wall) and then just align it with the truss.
If you find this useful, please subscribe to my channel https://www.youtube.com/channel/UCJZt58oErg137aaKJpfygRw
Paypal donations: omul-andrei@protonmail.com
Bitcoin dontations: bc1q9qgjlt7x2yt6uvv869qjyd4nsuz8nhxkg3ck73
Etherium dontations: 0x2B5B713491c2D83889d546C31C115548c642d070
336 Downloads
ViaDuct for Metro
ViaDuct for Metro
332 Downloads
Viga Canaleta (gutter beam)
Viga parametrica de hormigon, tipo canaleta
(Concrete Beam Parametric, type gutter)
5 Stars from 4 Votes
Product Version: Revit MEP 2010
3252 Downloads
Page 1 of 1 |
Page generation time: 0.5245
