Structural Column adjustable |
No rating |
274 Downloads
Industrial column - Cot nha cong nghiep 1 vai |
7144 Downloads
Industrial column - Cot nha cong nghiep 2 vai |
7256 Downloads
Fully Parametric Column with Drop Panel |
No rating |
Product Version: Revit Structure 2014
2277 Downloads
Fully parametric column with Drop Panel with Corner Cut |
No rating |
Product Version: Unknown
1184 Downloads
No rating |
1640 Downloads
COLUMNAS PREFABRICADAS PARA SISTEMA DE BALDOSA Y PREFABLOQUE, PARA MODULACIÓN CONTINUA, ESQUINAS, PERPENDICULAR, BUQUES Y COLUMNA SIMPLE.
SE PUEDE CONFIGURAR LA ALTURA |
No rating |
99 Downloads
Fully parametric Concrete Column Capital and Drop Panel |
No rating |
3005 Downloads
Parameters: Length, Width, and Thickness on both sides
(Fixed Material Graphics from the Older Version)
Enjoy and give your Feedback :) |
1482 Downloads
A parametric conical column I created for a project. |
No rating |
5186 Downloads
Fully parametric precast column with corbels on two sides.
No rating |
2372 Downloads
14" dia decorative column ( generic model)
parameters: materials and height of column
rate and comment for improvement |
29399 Downloads
Try it, use it, love it!
And please give me advices for further dev. ;)
http://revititthon.blogspot.com |
No rating |
1170 Downloads
This is a precast concrete column with optional haunches on two face and two heights. |
1829 Downloads
Fully parametric perimeter column with corbels on three sides.
No rating |
1707 Downloads
Fully parametric interior column with corbels on two sides.
No rating |
1930 Downloads
This is a precast concrete column with optional haunches on each face. |
2761 Downloads
General Pyramid Column that I had to use for a gate feature. Full Parametric. By Juul |
No rating |
3473 Downloads
Adjustable column:
- depth, width, distance....
- material |
4444 Downloads
Adjustable column:
- depth, width, f, y,
- material |
No rating |
2699 Downloads
Fully adjustable stud rails system. |
No rating |
Product Version: Revit Structure 2013
1545 Downloads
Revit 2014 Structural Concrete Column. I use it for a pier. |
No rating |
4765 Downloads
User controls: base width, top width, concrete structural support center width, top cap width, top cap thickness, column height, cap on/off. I did not include a stone hatch. That you'll have to put in. |
No rating |
6182 Downloads
