Parametric column base with adjustable bearing, gusset plate, and hole dimensions. |
4249 Downloads
3585 Downloads
Parametric column cap with adjustable bearing, gusset plate, and hole dimensions. |
No rating |
3639 Downloads
This is a fully parametric Craftsman Column with both material parameters and height, width etc. |
Product Version: Unknown
8876 Downloads
No rating |
590 Downloads
This is an awesome little family I must say. I have made a parametric column/girder/concrete base family where the you can control the number of columns and the column spacing. The girder cut length will follow as you enter the amount of columns you want. Can you believe I have totally mastered revit but still can't find a job!!! Please rate and comment. |
4578 Downloads
8"x8" Timber Column Wrapped With Stone at the Base |
2870 Downloads
Timber column with footing and metal stirrup shoe |
11764 Downloads
Metric Structural Column Family (Timber Post with Centre Fix Post Anchor). This Model is parametric allowing:Different Timber Post SizesAdjustment of Stirrup Foot HeightMaterial Assignment for Timber post and Stirrup assembly This is the first out of the ordinary Family that I have had to create and I thought I would make it my first contribution to RevitCity. I hope someone else out there can find useful. |
4706 Downloads
