Parametric base plate for a structural steel column. Plate dimensions and bolt size can be changed. |
7789 Downloads
It's not actually some sort of structure thing! but you can make something with it. it really looks like it holds the next floor!!! ;) |
9226 Downloads
Square steel column made of 4 steel plates |
No rating |
Product Version: Revit Structure 2013
4657 Downloads
A detailed parametric column used in Ludwig Mies' Barcelona Pavilion and Brno's Villa Tugendhat. Parameters are not 100 % functional, exceeding some might not work. You will see. |
No rating |
Product Version: Unknown
343 Downloads
Parametric structural connection, face based. To be hosted to the bottom of the column (or workplane and then use "flip workplane"). Metric Revit 2018. |
3660 Downloads
The only time I ever used this was working on a rock quarry. Maybe it will come in handy some where else. |
No rating |
1704 Downloads
3d rebar, can be used for rebar detailing |
1615 Downloads
A adjustable angle that can be used as a column. (The angle beam properties in REVIT will not let a beam become a vertical member (column) as far as i can tell) Adjust thickness, Length of each flange and Height. Will behave like a normal column |
Product Version: Revit Structure 2008
9756 Downloads
Strctural Steel Column Base plate w/
editable size & bolt spacing |
3591 Downloads
This family has been manipulated for anyone who wanted to have baseplates and cap plates on their columns. This is just a start of one family. more are to come. |
Product Version: Revit Structure 2009
3037 Downloads
Fully parametric C section created in Revit Architecture 2012. It comes with a type catalogue txt file that defines the available types. The section is produced by Lindab in Sweden.
The family type is Structural Column.
For the complete free of charge LindabRevitLibrary, visit www.lindab.com/buildingtechnology. |
3844 Downloads
Fully parametric RdBX section created in Revit Architecture 2012. The RdBX profile is a partition wall stud for high acoustic performance walls. It comes with a type catalogue txt file that defines the available types. The section is produced by Lindab in Sweden.
3724 Downloads
Fully parametric RY (slotted C) section created in Revit Architecture 2012. The RY profile is an exterior wall stud for high thermal performance walls. It comes with a type catalogue txt file that defines the available types. The section is produced by Lindab in Sweden.
No rating |
2526 Downloads
Remade the old one...more functional and easier to use |
No rating |
2544 Downloads
No rating |
1936 Downloads
Most parameters are instance so that you can adjust easier. Revit 2018 Version (Revit City is always behind). Family is a Structural Column as this seemed to work best. |
No rating |
Product Version: Revit Structure 2017
1740 Downloads
This brace is completely parametric. Width and Height are adjustable. |
No rating |
399 Downloads
Parametric steel base plate with bolt holes for structural column. |
6873 Downloads
This is a tower section which is 99% parametric. You can adjust the column thickness, overall width and length. The beams will adjust with the column dimensions. This tower section is placed as a "column".
A couple things:
1) The crossmember thickness is not adjustable. I don't know, i just had a hard time trying to set it up. If anyone wants to take it and run with it, please do.
2) To make a tall tower you simply stack these columns, if you want to adjust the height of a section you can set its offset from the level its on, then you have to adjust the column height to match. Simply changing the column height will NOT change the height of the section.
It's my first attempt at a parametric object. |
2666 Downloads
Structural Star column
fully parametric |
No rating |
Product Version: Revit Structure 2018
747 Downloads
Parametric Made in RAC 2010 |
No rating |
5277 Downloads
It's NOT PERFECT, but it's OK, you can fix what you want, Made in RAC 2010 |
3853 Downloads
STEEL COLUMN 12X65 + CONCRETE PEDESTAL & FOOTING |
No rating |
Product Version: Revit Structure 2020
1734 Downloads
Just like the tapered column you can change the flange thickness, web thickness, depth, and width of the start and end of beam independently. |
Product Version: Revit Structure 2012
13076 Downloads
Fully parametric |
4713 Downloads
Ability to change d, bf, tw, and tf of top and bottom of bottom seperatly. Great for metal buildings |
5335 Downloads
Contains all structural data. |
7435 Downloads
