Objects
Page 1 of 3 | 1 | 2 | 3 Next >>
3.5 Stars from 3 Votes
Product Version: Unknown
1519 Downloads
10' Chainlink Fence
10' Chainlink Fence
This was done with the railing tool. Super clean and easy to use. Copy from the RVT file to your Project. If you get ambitious, add some piles and a no tresspassing sign.
NOTE:
You may need to adjust the material to ensure it looks correct. The chainlink is a model line drafting hatch.
Also, if you change the height, you will need to adjust the 'Chainlink Fence Panel' Profile to suit.
Good Luck - RFB
4.5 Stars from 5 Votes
15174 Downloads
50% Transparent Fence
fence used in residential projects, 50% transparent. Used as a component, not a railing. Parametric in length and can adjust the number of posts and material
2013
21939 Downloads
Animal Package
Cow, horse, duck, chicken, pig, calf, goat, lamb
Made in 2003
3 Stars from 14 Votes
10217 Downloads
ASADOR / GRILL EXTERIOR
4.5 Stars from 6 Votes
18756 Downloads
Bench - Design by Nola - Concrete and Red Oak Slats
Typical parameters including length / height / materials
Width is a set dimension.
7471 Downloads
Bird Bath
blue ceramic bird bath
1740 Downloads
Bird Bath
1187 Downloads
Box type letterbox
Box type letterbox
Paramtric letterbox, can change number, material and width
2073 Downloads
Bridge
Bridge
Small footbridge for garden or landscape feature. Non-parametric.
6878 Downloads
Bus Stop
Bus Stop
Very beautifull bus-stop for landscaping and architecture use in all type of revit projects.
2086 Downloads
Bus Stop - Curved Glass
UK_Bus Stop - Curved Glass
Product Version: Revit Building 8
16094 Downloads
Bus Stop - Modern
Bus Stop - Modern
UK_Bus Stop - Modern
20937 Downloads
Cambridge Trash Receptacle
5220 Downloads
3 Stars from 2 Votes
8861 Downloads
Chica & Moto!!!
Chica & Moto!!!
Totalmente hecho por mi!!!
4 Stars from 4 Votes
3523 Downloads
Children's PlayEquipment
5 Stars from 4 Votes
22018 Downloads
Children's Spring Seater
Children's Spring Seater.
5 Stars from 2 Votes
7858 Downloads
City Entryway Sign
City Entryway Sign
**UPDATED**A sign that I designed for a project we are working on, if you want to edit the material, you will have to edit the family, also the ivy doesn't show up unless you set up a rendering material. The text on the sign is just an example, was an added mass in the project
3 Stars from 1 Votes
2860 Downloads
close frame
close frame
شده معدنيه
شباك معدني light weight
scaffolding -light weight close frame 1*2 m
Product Version: Revit Structure 2019
243 Downloads
Concrete Litter Bin
Concrete Litter Bin
Precast Concrete Litter Bin or Cigarette snuffer. Most precasters supply these to go outside retail or convienience stores. Two simple parameters height & diameter.
10323 Downloads
Cornhole (Bags) Boards
Regulation size and spaced concrete cornhole boards. Area of play next to boards has been marked.
1920 Downloads
Courtyard Wall- Post & Lattice 1500H
Fully adjustable courtyard wall except for height.
4.5 Stars from 9 Votes
13353 Downloads
Curtainwalll Lattice
Create simple curtainwall Lattice
4228 Downloads
Farm Fence (Revit 2016)
Farm Fence with paramaters:Fence Height,Fence Length,Board Spacing, Number of Boards, Number of Posts, Post Bury Depth, Top Board Offset
Revit 2016
11665 Downloads
Fire Pit
Fire Pit
Fire Pit with flames that can be turned on or off. For the fire material, please see my "Fire with Logs" family for the material image.
25893 Downloads
Flame toppers fence posts
1074 Downloads
fountain
fountain
my first upload
4.5 Stars from 2 Votes
10183 Downloads
fountain
fountain
3.5 Stars from 7 Votes
48372 Downloads
Frosty
Frosty
Just a snowman
4 Stars from 1 Votes
2104 Downloads
Page generation time: 0.6323
