48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
9' x 18' face hosted parking stall
Parking stall that will host itself to sloped objects (like sloped double tees in my case).
4 Stars from 1 Votes
2388 Downloads
Accessible Parking Sign
Post Sign
3013 Downloads
Accessible Pavement Sign
Adjustable sign
8334 Downloads
Accessible Sign Post
2.5 Stars from 3 Votes
2418 Downloads
AGRV_PRKG_Car-AD-Dropoff_無障礙汽車下車區
Accessible Design Parking Dropoff and strip with DIM & Material parameters and dimension Guide
All size is basic on Taiwan architecture regulation.
Visit our website AgileRevit.com for more families
610 Downloads
AGRV_PRKG_Car-AD_無障礙汽車停車位
Accessible Design Parking Space and strip with DIM & Material parameters and dimension Guide
I use shared parameter so you can easily count them using schedule.
335 Downloads
AGRV_PRKG_Car_汽車停車位
AGRV_PRKG_Car_汽車停車位
AGRV_PRKG_Car_汽車停車位
Parking space and strip with DIM & Material parameters and dimension Guide
644 Downloads
AGRV_PRKG_Motorcycle-AD_無障礙機車停車位
Accessible Design Motorcycle Parking Space and strip with DIM & Material parameters and dimension Guide
289 Downloads
Bolardo Madrid
Bolardo Madrid
Bolardo existente en las calles de Madrid
Product Version: Revit MEP 2019
168 Downloads
Bolardo Madrid
Bolardo Madrid
181 Downloads
Bolardo Madrid
Bolardo Madrid
376 Downloads
Bolardo Madrid
Bolardo Madrid
326 Downloads
California Accessible Parking Stall
This stall is for a single or double accessible stall for California.  Includes Van Accessible (8') as well as standard (5')
5 Stars from 2 Votes
9688 Downloads
Car Parking Roof Tent
Car parking roof tent in fabric finish for 2 cars slot on 1 column support
6117 Downloads
Covered Parking line based with post & fabric cover
4876 Downloads
crosswalk stripe
crosswalk stripe
crosswalk stripe
3 Stars from 3 Votes
Product Version: Unknown
7793 Downloads
crosswalks
crosswalks
fixed width and distance (50 cm). Parametric: number series, length, material.
4.5 Stars from 4 Votes
19799 Downloads
Disabled Parking Bay
UK standard Disabled Parking Bay
11111 Downloads
Escudo Ayuntamiento Madrid
Escudo de la Ciudad de Madrid
54 Downloads
Exclusivo para Discapacitados en Estacionamientos
Modelo para estacionamiento exclusivo de discapacitados paramétrico con una altura libre de 1.75m.
Disfrutenlo. Saludos
4693 Downloads
Handicap Parking (Parqueo para Discapacitados) Spanish
Estacionamiento con franjas en espacio de 3.50m x 5.00 m y simbologia vertical/ Parking Space for Handicap in a space of 3.50 m and 5.00 m or 11´6" and 16´5"
19614 Downloads
Handicap Parking Sign
ADA handicap sign
4 Stars from 5 Votes
4733 Downloads
Handicap Parking Stall Symbol
A blue and white HC Parking Symbol with material adjustability
***UPDATED!***  It looks like I messed up the upload last time and didn't give you all the correct file, so I've fixed the background issue and added some more flexibility with background size, stripe width, and visibility options.  I also added "VAN" Lettering as an instance parameter with adjustable distance from the symbol to the lettering.
13017 Downloads
Handicap PArking Symbol
ADA parking symbol
4552 Downloads
HeliPad
HeliPad
A helicoptor landing pad for a Bell 412 Commerical Helicoptor. Paved FATO and TLOF, inside fenced area.
2 Stars from 2 Votes
10322 Downloads
Mcdonalds Drive Thru Lettering For Site
This is the lettering That I created of the Mcdonalds Drive Thru Paint. I created this.
Product Version: Revit Structure 2017
1426 Downloads
Nombre Calles Ayuntamiento Madrid
Letrero del Nombre de las calles del Ayuntamiento de Madrid
125 Downloads
Parametric Face Based Pedestrian Crossroads Marking
Parametric Face Based Pedestrian Crossroads Markings, instance parameter for length, equation setting the number of markings and the spacing between each, type parameter for width and depth
6126 Downloads
Parking Component- White Stripe on slope only
do not set slope to 0- use the out of the box stripe for those.  Work around for host issues with topo surfaces.
Product Version: Revit Building 9.1
2034 Downloads
1400 Downloads
Page generation time: 0.7074
