Wall Mounted 3" Cows Tongue Wall Drain |
4950 Downloads
No rating |
2044 Downloads
No rating |
1035 Downloads
No rating |
881 Downloads
Parametric Downspout |
Product Version: Unknown
4673 Downloads
Cow Tongue Wall Scupper Outlet - based on a 3" pipe diameter. This family has an instance parameter called "Wall Offset", which allows for adjustments for walls with a thicker base than upper portion. Initial placement is to the exterior face of wall. Once placed, adjust the wall offset parameter to bring it out to the finished face of stacked walls. |
3428 Downloads
Cow Tongue Wall Scupper Outlet - based on a 6" pipe diameter. This family has an instance parameter called "Wall Offset", which allows for adjustments for walls with a thicker base than upper portion. Initial placement is to the exterior face of wall. Once placed, adjust the wall offset parameter to bring it out to the finished face of stacked walls. |
3982 Downloads
Wall based downpipe |
14652 Downloads
exterior downspout gutter |
16817 Downloads
No rating |
1494 Downloads
Fountain effect after Render |
No rating |
6057 Downloads
Face Base Model
-Floor Trap with Dome Grating at scupper drain for rain water system. |
No rating |
6935 Downloads
3660 Downloads
HAND SHOWER SLIDE BAR |
No rating |
Product Version: Revit MEP 2013
7945 Downloads
No rating |
3722 Downloads
No rating |
1084 Downloads
Overflow nozzle for thru wall roof drain piping. Revit 2014 |
No rating |
1922 Downloads
The JUAL Angular bowl outlet consists of a bowl which cumulates the water before it is led to the pipe system of the building. The outlet is delivered with standard pipe diametres 50, 63 and 75 mm.The bowl outlet is made from stainless steel and is delivered with Integrated bitumen or foil membrane.
No rating |
Product Version: Revit Architecture 2019
121 Downloads
The design of JUAL angular roof outlet is similar to the vertical roof outlet, but the pipe has a 92° angle immediately after the intlet so water is drained horizontally from the roof. The angular roof outlet can be supplied in all standard diametres from 50 mm to 110 mm with various roof membrane types. |
No rating |
106 Downloads
No rating |
219 Downloads
No rating |
197 Downloads
The vertical bowl outlet consists of a bowl that cumulates the water before it flows down into the pipe system of the building via vertical pipes of standard diametres from ø50 to ø110 mm.Bowl outlets are made from stainless steel and can be delivered with integrated bitumen or foil membrane. |
No rating |
108 Downloads
No rating |
114 Downloads
JUAL Outlet with rectangular pipe. The outlet can be supplied in many different standard dimensions with a cross section ranging from 77x56 to 500x100 mm and lengths from 400 mm to 1000 mm.
No rating |
90 Downloads
No rating |
43 Downloads
No rating |
42 Downloads
JUAL Outlet with a rectangular pipe and 90° angled flange. The outlet can be supplied in many different standard dimensions with cross sections ranging from 77x56 mm to 500x100 mm and lengths from 400 mm to 1000 mm. |
No rating |
60 Downloads
No rating |
36 Downloads
No rating |
42 Downloads
No rating |
33 Downloads
