Product Version: Revit MEP 2010
11319 Downloads
a 4 way junction of 50mm pipes into 100mm drainage |
No rating |
Product Version: Unknown
0 Downloads
Product Version: Revit MEP 2016
1674 Downloads
Wavin Access Junction Straight Through |
No rating |
23 Downloads
ACO based 1 meter K/KS series trench drains. Modules K1 - K30 including Nutral Channel componants. on/off bottom and down stream 4" SS connectors. 3D fine and 2D medium and coarse representations |
12190 Downloads
ACO based half meter K/KS series trench drains. Modules K0013 - K0303 Nutral Channel componants. on/off bottom and down stream 4" SS connectors. 3D fine and 2D medium and coarse representations |
No rating |
5702 Downloads
ACO linear drainage system, produced by ACO DRAIN A/S, Denmark. Load class is defined according to DIN 19 580 Prices are in LTL, valid at year ~2000 (sorry, i have no newer data) Family is based on Trench_drain.rfa file. This is a floor-based element. Use type catalog to edit data, please |
No rating |
1699 Downloads
ACO linear drainage system, produced by ACO DRAIN A/S, Denmark. Load class is defined according to DIN 19 580 Prices are in LTL, valid at year ~2000 (sorry, i have no newer data) Family is based on Trench_drain.rfa file. This is a surface-based element. you can place ir on any surface (floor. ramp, pad). Use type catalog to edit data, please |
1810 Downloads
P-Trap placed under kitchen sink to provide air gap
this fixture prevent cross contamination. |
No rating |
1720 Downloads
No rating |
585 Downloads
Drainage-Gully |
No rating |
3381 Downloads
Drainage-Marley M08-Grid |
7288 Downloads
steel |
1710 Downloads
Floor drain 75mm - ACO 20/50 modulair |
3242 Downloads
Floor trap(floor base) for toilet
5498 Downloads
No rating |
904 Downloads
Hand-Dryer Commercial Recessed Concealed |
Product Version: Revit MEP 2013
5714 Downloads
Contains sink, trash, ultraviolet sensors, fuset, sanitiser, washing agent, rubber gloves holder.
made from stianless steel sheets |
2815 Downloads
Face Based Multi sink Includes three most common type of Kitchen sink
- Single Bowl
- Double
- Triple Bowl
Will add more sink type in future updates your comment are welcome. |
No rating |
17860 Downloads
This is fully Parametric and has family types already made in the following sizes: 2,000, 4,500, 10,000 + 45,000Ltrs. Plenty of parameters are in place in order to make custom sizes. Materials have likewise been set up to represent your preferred colours + textures. |
5350 Downloads
Parametric rectangular floor drain with sizes from 20cm to 1m length drained in to 50mm pipe |
No rating |
2433 Downloads
Parametric family with constraints to Bottom ridge, Sump rise, Sump, Leader diameter, etc... |
No rating |
1841 Downloads
4997 Downloads
Parametric family of Square Floor Drain with sizes of 50, 75, 100mm Drain
Designed with Revit 2021 |
No rating |
3680 Downloads
No rating |
1484 Downloads
I modified a beam to look like the seam of a metal roof. Just draw your path, disjoin, and rotate to set upon your metal roof. The base material is Copper, but you can change that in the properties dialouge. RAC 2009. |
13311 Downloads
Toilet Elongated Contemporary Neorest |
11514 Downloads
Parametric drain |
9195 Downloads
Floor based trench drain. Length fully parametric. Either type in length or align/stretch. Set up to render. Trench drain based on Aco KlassikDrain (see link)http://www.acousa.com/drain/klassikdrain.htm |
10909 Downloads
Urinal Commercial |
14208 Downloads
