33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
5A 120V Surface Mounted Exit Sign - Parametric
With Parametric Elevation & Annotation Flipping
5 Stars from 3 Votes
9630 Downloads
Ceiling Mounted Exit Sign
Parametric Exit Sign.
Family is face based so it can be used on a linked ceiling.
Available parameters:
  Color of letters (Red or Green)
  1 Sided or Two Sided
  Arrows to left or right
Product Version: Revit MEP 2010
4108 Downloads
Commercial Exit Sign
Product Version: Unknown
7351 Downloads
Emergency Exit Light
A ceiling mounted emergency exit sign
11250 Downloads
Emergency exit sign with (2) lamps
17399 Downloads
Emergency Exit Sign
Emergency Exit Sign
6256 Downloads
Emergency Light
Emergency Light
Emergency light with (2) heads
13796 Downloads
Emergency Light
Emergency Light
This is LSI model EPM. It is their low-profile eyeball fixture in the standard white color.
3176 Downloads
EMERGENCY LIGHT
EMERGENCY LIGHT
3232 Downloads
exit sign
exit sign
960 Downloads
Exit Sign
Model Exit sign with direction of travel symbol.  This is modified version of someone else's exit sign.
1 Stars from 1 Votes
4470 Downloads
Exit sign - Lumacell Model LER2301
simple face based component. Revit 2012
4769 Downloads
Exit Sign / Emergency Light
three options: top lights, side lights; no lights
this is made as a light source; comes with an electrical connector. not really parametric except for the angle of the lamp
Modelled in Revit 2012
3.5 Stars from 3 Votes
9005 Downloads
Exit Sign / Emergency Light Combo
this is made as a light source; comes with an electrical connector. not really parametric except for the angle of the lamps
9246 Downloads
Exit Sign By Safe Glow
 http://www.safeglow.com/PhotoluminescentProducts.ExitSign.home.html
Professional Interiors Line UL 924 Certification Safe Glow’s™ Professional Interior Exit Signs are UL listed to meet UL 924 standards. The Safe Glow™ Underwriters Laboratories certification number is:  35JS. Professional Interior Exit Signs have 6” letters and are certified to have a viewing distance of 50 feet. Professional Interior Exit signs with 8” letters are available upon request.
4 Stars from 1 Votes
12435 Downloads
Exit Sign_Edge-Lit_Ceiling-Mount
Double or single-sided ceiling-mount exit sign with adjustable directional arrows both in model and symbol. Model hides in coarse view settings. Symbol shows in plan or RCP views. Symbol hides in fine view setting, or as a parameter. No actual light source.
15390 Downloads
Multifunctional Exit Symbol
Exit symbol with multi ways to indicate egress See picture.
4.5 Stars from 3 Votes
Product Version: Revit Structure 2015
5857 Downloads
Modified wonderful Exit sign by smitholino.  Changed following:  Parametric properties are Instance Base; Except color of sign.  Allows user to change individual signs.  Made symbol smaller scale.  Made directional arrows show with symbol. UPDATE (2010-10-08):  Fixed directional arrows matching between symbol & 3d element.
4.5 Stars from 5 Votes
12785 Downloads
19320 Downloads
Page 1 of 1 |
Page generation time: 0.4514
