![002-Kamals Electrical Power Transformer](object_docs/23007_s.jpg) |
Power Transformer designed carefully to siute your project. |
![5 Stars from 1 Votes](/images/stars_5.gif)
1588 Downloads
![Back to the Future Flux Capacitor](object_docs/19554_s.jpg) |
Remake the Back to the Future Flux Capacitor within Revit |
No rating |
535 Downloads
![Dry Type Transformer 1600kVA](object_docs/20649_s.jpg) |
Dimensions are Based on Kahramaa Qatar. |
No rating |
Product Version: Revit MEP 2019
1550 Downloads
![Eaton model TP1 Energy Efficient Transformers](object_docs/12304_s.jpg) |
http://www.eaton.com
NEMA TP-1 transformers are typically installed in commercial construction, as well as in educational (K–12 and universities), government and industrial facilities. NEMA TP-1 compliant transformers are especially designed to have low no-load (core) losses.
No rating |
1507 Downloads
![ELECTRIC DRIBE TRUCK](object_docs/12540_s.jpg) |
BIG ELECTRIC DRIVE TRUCK |
![2 Stars from 4 Votes](/images/stars_2.gif)
8097 Downloads
![Gaming Workstation](object_docs/14923_s.jpg) |
Hi Guys
I was looking for something extreme and loosely based this on the Emperor 200 gaming station.
As spatial planning is part of my job I needed to get an idea of how big this unit would be.
This is a very rough model but works for what I need. |
![4 Stars from 3 Votes](/images/stars_4.gif)
7485 Downloads
![High Voltage Exterior Transformer](object_docs/15736_s.jpg) |
![3 Stars from 1 Votes](/images/stars_3.gif)
Product Version: Unknown
6022 Downloads
![Kamals Electrical Transformer With Distribution Board](object_docs/23006_s.jpg) |
Newly designed electrical power transformer with control board combine and a concrete footings. |
969 Downloads
Simple Parametric Concrete Pad and Electrical Transformer |
![1 Stars from 1 Votes](/images/stars_1.gif)
3834 Downloads
![switchyard transformer and pole](object_docs/4795_s.jpg) |
Switchyard transformer and pole |
No rating |
2422 Downloads
![Transformador de 10kVA](object_docs/18169_s.jpg) |
Tranformador Trifasico 10kVA
O Autor possui toda linha de equipamentos de baixa/média/alta tensão bem como desenvolvimento de subestações elétricas e modelagem de equipamentos e demais elementos paramétricos
contato@4revit.com.br |
No rating |
Product Version: Revit MEP 2016
1064 Downloads
![Transformador de alta tensão](object_docs/15809_s.jpg) |
High voltage transformer to lamppost (Brazil) - not parametric. |
![2.5 Stars from 3 Votes](/images/stars_2.5.gif)
5878 Downloads
![Transformer on pad w Bollards (parametric)](object_docs/21677_s.jpg) |
very basic family but it works. Parametric Pad and electric transformer. |
No rating |
750 Downloads
![transformer1](object_docs/4793_s.jpg) |
Electrical transformer made in Revit drawn by Jeff Rath www.3d3ntourage.com |
3693 Downloads
![transformer2](object_docs/4794_s.jpg) |
Transformer drawn by Jeff Rath in Revit www.3dentourage.com |
4319 Downloads
![Transformers Ventilated Harmonic Mitigating](object_docs/12399_s.jpg) |
Eaton’s harmonic mitigating transformers (HMTs) are specially designed transformers that treat a wide variety of harmonics.
480V to 208/120V standard150° or 115°C temperature rise available Copper windings and terminals standard CSL-3 2007 Final Rule efficiencies levels increased efficiencies help to gain LEED points |
No rating |
720 Downloads
![Transformers Ventilated K Factor](object_docs/12400_s.jpg) |
Eaton K-Factor transformers are specifically designed to withstand the harmful overheating effects caused by harmonics generated by nonlinear (non-sinusoidal) loads. These loads include computers, laser printers, copiers and other office equipment, as well as video monitors and other electronic equipment.
![3.5 Stars from 3 Votes](/images/stars_3.5.gif)
1100 Downloads
![Transformers Ventilated Type CSL3](object_docs/12398_s.jpg) |
No rating |
503 Downloads
![TWO POLE STRUCTURE](object_docs/21587_s.jpg) |
682 Downloads
