44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
3-lamp stainless steel ceiling mounted track light
4 Stars from 13 Votes
Product Version: Unknown
48011 Downloads
BRUCK V/A CALO SPOTII
PARAMETRIC TRACK LIGHT SET TO THE 3 SIZE PER MANUFACTURER SPECS. 39" 78" 102"
BRONZE, CHROME, GOLD, MATTE CHROME
YOU CAN SPEFICY ANY NUMBER OF LIGHTS AS LONG AS THEY FIT THE RUN LENGTH.
5 Stars from 4 Votes
9799 Downloads
Gimble Ring Track Head
This is the same as the other gimble except that materials have been changed to make it work
5 Stars from 3 Votes
11431 Downloads
9346 Downloads
LED Tape / Fita de LED
[EN] This is a Lighting Fixture Family based on a pan. Fully parametric.
[PT-BR] Esta é uma familia de luminária com base no plano. Completamente paramétrica.
4 Stars from 15 Votes
36254 Downloads
M_Downlight - Spot (Work Plane Base)
326 Downloads
Parametric Track Lighting
This is a modified version of 'Parametric Track Light w/ Gimble Fixture'. I made so the lights would be centered on the track.
12326 Downloads
Pendant Light with cage
Pendant light with a wire cage around the glass shade. Edison style bulb.
Face based, so can be mounted to track.
1403 Downloads
PureEdge Pipeline 10' Track w/Uplight and Adjustable Cans
Please rate and comment, thanks!
Took a while to figure out how to get these to work properly.
The track is PureEdge Pipeline with LED uplight (very cool!).  Available in 2', 4', 6', 8', and 10' lengths.  I'll be uploading the 4'-10' pieces.  The hanging height is parametric, but the number of cans and can spacing will have to be changed in family editor.
The cans are focus adjustable, dimmable, gallery series artwork LED cans found at cocoweb.com
Cans be individually rotated in project.
!!!DO NOT ROTATE THE CANS BEYOND 179 OR -179 DEGREES OR THEY WILL EFF OFF INTO LOW EARTH ORBIT!!!
Can pitch can be individually adjusted but should be kept between 15 and 105 degrees (for some reason the ACTUAL angle is off by 15 degrees, so entering 15 will set the can to zero, or parallel with the track).
The can light sources are point+spot.  The beam angle and sourounding field angle can be adjusted as well.
You can add cans, but will have to add the corresponding parameters and labels to make the new cans function properly. You'll also have to save the new can as a seperate family, ie. "Can 7", "Can 8", etc.  This was the only was i could figure to get the individual pitch parameters to work.
I'm sorry if there's a better/easier way to do all this, but I'm self taught and there's still a lot I don't know.
Hope these are helpfull for you!
1027 Downloads
PureEdge Pipeline 4' Track w/Uplight and Adjustable Cans
Please rate and comment, thanks!Took a while to figure out how to get these to work properly.The track is PureEdge Pipeline with LED uplight (very cool!).  Available in 2', 4', 6', 8', and 10' lengths.  I'll be uploading the 4'-10' pieces.  The hanging height is parametric, but the number of cans and can spacing will have to be changed in family editor.The cans are focus adjustable, dimmable, gallery series artwork LED cans found at cocoweb.comCans be individually rotated in project.!!!DO NOT ROTATE THE CANS BEYOND 179 OR -179 DEGREES OR THEY WILL EFF OFF INTO LOW EARTH ORBIT!!!Can pitch can be individually adjusted but should be kept between 15 and 105 degrees (for some reason the ACTUAL angle is off by 15 degrees, so entering 15 will set the can to zero, or parallel with the track).The can light sources are point+spot.  The beam angle and sourounding field angle can be adjusted as well.You can add cans, but will have to add the corresponding parameters and labels to make the new cans function properly. You'll also have to save the new can as a seperate family, ie. "Can 7", "Can 8", etc.  This was the only was i could figure to get the individual pitch parameters to work.I'm sorry if there's a better/easier way to do all this, but I'm self taught and there's still a lot I don't know.Hope these are helpfull for you!
440 Downloads
PureEdge Pipeline 6' Track w/Uplight and Adjustable Cans
469 Downloads
PureEdge Pipeline 8' Track w/Uplight and Adjustable Cans
658 Downloads
Recessed Magnetic Track Lights
Product Version: Revit MEP 2020
40 Downloads
22 Downloads
21 Downloads
61 Downloads
rope light array
rope light array
just a simple array of lights I use for accent lighting. let me know what you think.
4 Stars from 1 Votes
13960 Downloads
SIMPLE TRACK LIGHTING
THIS IS A SIMPLE 4' TRACK LIGHT SECTION WHERE ALL 3 OF THE LIGHTS WORK. TO ADJUST THE DIRECTION OF THE LIGHTS YOU WILL HAVE TO GO INTO THE FAMILY FILE AND ROTATE THEM
21254 Downloads
Suspended Light
Suspended Light
A sqaured suspended light system. Very modern and stylish. 4'8'' x 4'8''
Material/Color parameters
4.5 Stars from 4 Votes
Product Version: Revit MEP 2011
23141 Downloads
Suspended Liner Light Fixture
Product Version: Revit MEP 2018
559 Downloads
Track Light
Track Light
Parametric
4414 Downloads
track light
track light
2125 Downloads
Track light adjustable.
2.5 Stars from 4 Votes
Product Version: Revit Building 9.1
47507 Downloads
Track Light Parametric w/Gimble fixture
Took a parametric track from here and added the Gimble fixture. Now the fixture symbol does show up in the RCP. The track however is still just detail lines, so it is a no show in elev or 3D views.
4.5 Stars from 2 Votes
6754 Downloads
track light with correct lighting
This is actually a group so in order to use it, change the file extention to .rvg and load it into a project. you can do an edit group to reposition the individual lights. The important part is that you get light from all 5 heads not just one like other the other track light families out there.
2.5 Stars from 14 Votes
51299 Downloads
Track Lighting
Track Lighting
Track Lighting
1 Stars from 1 Votes
5654 Downloads
track lighting - 2 fixtures
13819 Downloads
track lighting - 3 fixtures
2.5 Stars from 2 Votes
48063 Downloads
Track Lighting - Parametric
Track lighting family offers basic rcp sybol and provides correct number of fixtures accordign to track length and light spacing parameters.  Good base to start looking at shared families to pull your own light fixtures into.
10073 Downloads
Track Lights Parametric
This is the new and improved family (ceiling based.) You can change the length and the number of lights and it will space them evenly.
The main difference between this and the old one is that each light is a light source, instead of just the middle one.
2 Stars from 2 Votes
19585 Downloads
Page 1 of 1 |
Page generation time: 0.6377
