90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
4' Dia. Dome Light
4' Dia. Dome Light
Model off of the Mark Architectural Lighting Magellan Series. Very Detailed
4.5 Stars from 5 Votes
19148 Downloads
5" Clear Specular Downlight
4 Stars from 16 Votes
Product Version: Unknown
70557 Downloads
Basic Recessed Can
1875 Downloads
Downlight
Downlight
Downlight can
3.5 Stars from 6 Votes
29468 Downloads
DOWNLIGHT - DLR617
DOWNLIGHT - DLR617
INTERIOR DOWNLIGHT CCT 6"
631 Downloads
Downlight Can That works
Have you had trouble having your cans turn on whike rendering? If yes use this for your cans from now on. You place in to your project on the ceiling plan just like you would a normal can.
PLEASE LEAVE A COMMENT ABOUT THIS LIGHT!
6795 Downloads
Drop Cord Fixture
Drop Cord Fixture
Drop Cord Light for Revit Electrical
-Parametrical
-Annotated in Elecrical Plan
410 Downloads
Floor Light
A light that resides in the floor and shoots up.
9923 Downloads
Generic round surface mounted or recessed light
Minimalist generic round downlight/uplight/wall light
Why this lamp?
* mounts on all surfaces (ceilings, floors, walls, objects, etc.)
* optional lens and diffusor
* recess parametrizable (any distance from surface, incl. surface mounting)
* diameter and depth scalable in large ranges (depth down to 20 mm!)
* realistically rendering (metal reflector, dimmed diffusor when lamp off)* minimalist design
* all parameters thoroughly documented
* no junk parameters, well almost… :)
4 Stars from 1 Votes
5013 Downloads
GRID IN
GRID IN
Created and Designed by Delta Light, this interior recessed fixture, the is the Single Head confirguration. There is a single, double, triple, and quad head options. Full photometric data.
7575 Downloads
GRID IN DOUBLE
GRID IN DOUBLE
Created and Designed by Delta Light, this interior recessed fixture, the is the Double confirguration.  There is a single, double, triple, and quad head options. Full photometric data.
5935 Downloads
GRID IN QUAD
GRID IN QUAD
Created and Designed by Delta Light, this interior recessed fixture, the is the QUAD confirguration.  There is a single, double, and triple head option.
5 Stars from 2 Votes
6659 Downloads
GRID IN TRIPLE
GRID IN TRIPLE
Created and Designed by Delta Light, this interior recessed fixture, the is the TRIPLED confirguration. There is a single, double, and quad head fixture option.
3 Stars from 2 Votes
5020 Downloads
Light - LED Recessed fixture - Double
LED Recessed fixture use for Living room, Kitchen, Bedroom ceiling...
♥Enjoy ♥ !
7358 Downloads
M125 Recessed Flanged - M125R1-1T5
M125 - Is designed and manufactured to withstand the most demanding subways, tunnels, parking garages, stairwells and other high traffic general area lighting applications. M125 is IP65 and NRTL rated for wet location applications! It features a vandal resistant, high-impact polycarbonate prismatic satine lens or a non-prismatic satine lens. The M125 low profile housing is 5” wide and only 3.5” deep! Individual 3’ or 4’ (nominal) lengths available with options for single or twin T5, T5HO, and T8 lamping. M125 is designed to be functional and look great!
1 Stars from 1 Votes
5588 Downloads
M125 Recessed Flanged - M125R1-1T8
2422 Downloads
M125 Recessed Flanged - M125R1-2T5
2172 Downloads
M125 Recessed Flanged - M125R1-2T8
3176 Downloads
MINIGRID IN
MINIGRID IN
Created and Designed by Delta Light, this interior recessed fixture, The MINIGRID IN is housed in a recessed can.  Full photometric data included. Comes in Single, Double and Triple Configuration.
5374 Downloads
MINIGRID IN 02
MINIGRID IN 02
2828 Downloads
MINIGRID IN 03
MINIGRID IN 03
2828 Downloads
Plafon 01
Plafon 01
I started studying modeling families. I hope you guys enjoy.
4505 Downloads
Pot Light
Pot Light
Recssed Pot/Can light. Meant for kitchens but these stylish light can be used anywhere around the house or building. Enjoy!
43595 Downloads
Recessed adjustable spot
This has an arrow to indicate the direction of the lighting. Performs pretty well in rendering, although adjusting it requires editing the family and rotating a tube that controls the light
4992 Downloads
Recessed Can - 6 inch with trims
6" recessed can light with multiple trim options
5 Stars from 3 Votes
26993 Downloads
Recessed Can Light
Recessed Can Light
BR40 Can Light Structure
Ceiling Based Object
Enjoy!
5 Stars from 4 Votes
29862 Downloads
Recessed cans Ceiling light
Full parameter:
Shade size,
Shade material and glass cover
41380 Downloads
Repost the previous post for fix the missing opening cut error, tested image render by PC.
Full pareameter of Cans size, materials, on/off glass cover,...
22945 Downloads
Recessed wall washer
This has an arrow to indicate the side which get washed. It performs with a pretty high cutoff angle in rendering, producing even wall washing almost up to the ceiling plane.
Product Version: Revit Building 9
2771 Downloads
Square Recessed Lighting Fixture
1 Stars from 2 Votes
1948 Downloads
Page generation time: 2.6043
