58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
3-Roll Toilet Paper Dispenser
Product Version: Revit Building 8.1
9449 Downloads
Bobrick B-3471
Sanitary napkin and toilet paper dispenser two sided thru wall with partition thikness parameter
Product Version: Revit Building 9.1
1905 Downloads
CWS Stainless Steel Paperroll - BIMobject
Download: http://bimobject.com/en/cws-boco/product/7205000
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-app
Paradise Stainless Steel Paperroll roll paper hand towel dispenser for 100 m of paper roll, 22 cm wide. Paper can be removed in sections measuring approx. 25 cm (easy pull-out). Automatic cutting system with protective cover to prevent injury. Next section fed to within reach. "Easy-Loading" system for quick filling. Housing including rear wall made of matt brushed stainless steel 1.4301, brushed satin finish protects against fingerprints, with lock. Rounded edges ensure no risk of injury. Comes complete with fastening materials, delivery and installation.
Dispenser:
Stainless Steel Paperroll: 7205000
Roll paper:
white, 100m, 3-ply: 288001, blue, 100m, 3-ply: 289000
6162 Downloads
Dual Toilet Paper Dispenser - Bobrick B-2840
2 Stars from 1 Votes
Product Version: Unknown
7566 Downloads
Recessed Facial Tissue Dispenser
Wall hosted recessed facial tissue dispenser. no default heigth
1184 Downloads
Wall mounted Toilet Paper Dispenser, one with paper one without
12698 Downloads
Toilet paper holder
Toilet paper holder
Standared face based Toilet paper holder. Toilet paper visual can be turned on/off (instance based).
Revit 2015
hope it helps
41416 Downloads
Toilet Paper Roll
Toilet Paper Roll
Toilet roll holders are easy enough to find, but it bothered me that there was never any toilet paper on them. I looked and there didn't seem to be TP anywhere, so... now there is!
Change the elevation to line it up with your toilet paper holder. It's not wall based, so you can rotate it and stack some spare rolls in the bathroom, too.
Created in Revit 2022.
2094 Downloads
Toilet tissue dispenser
Toilet paper dispenser
4 Stars from 4 Votes
29961 Downloads
Towel Rack
Towel Rack
Wall Towel Rack
4.5 Stars from 9 Votes
42553 Downloads
TP Holder Double Roll
Revit Modeled No DWG
1884 Downloads
TP Holder Jumbo Double
1912 Downloads
Page 1 of 1 |
Page generation time: 0.3231
