25 Users Online (24 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 3 | 1 | 2 | 3 Next >>
Adjustable Wall Shelving
I spent a whole day creating this VERY parametric adjustable shelving family - I might as well save other folks out there some time and put it out here. (It is a wall based casework family)
3.5 Stars from 5 Votes
5545 Downloads
Book shelf antique (wall based)
Product Version: Revit Architecture 2019
3592 Downloads
Book Shelves
Book Shelves
  • Made from teak wood
  • Dimension:  11 1/2W X 58 1/2L X 37 1/2H inches
4 Stars from 2 Votes
10584 Downloads
Braced Counter
Braced Counter
Stone countertop with an open bottom.
Paremetric-- can change backsplach height, width between brackets, width between edge and the side brackets, and the height.
Product Version: Unknown
2126 Downloads
Built-in Shelving
Built-in Shelving
Built-in shelves with 1x support ledgers meant for niches, closets, etc. Parametric With, Height, Depth, Mouting Height, Number of Shelves.
3.5 Stars from 6 Votes
14271 Downloads
cabinet storage
cabinet storage
ira an storage cabinet for childern room.
5615 Downloads
circle shaped shelf
circle shaped shelf
1212 Downloads
Corner Pyramid Shelf
Modern Corner Pyramid Shelf - Mulit-Level Shelves, 90 degree base w/ 1/4 Circle Shelves, Triangular Tapered Vertical Supports w/ Glass Inserts , Descending + Recessed Pattern of Shelves
Visit my website at http://www.4u2cdesign.com
5 Stars from 2 Votes
18844 Downloads
Corner Shelving
Corner Shelving
4704 Downloads
Cubby in Wall
Cubby in Wall
Cubby for a wall.
All parameters are instances from width, height, trim size, depth, and materials.
You can also turn the frame off if you just want an inset shelf.
Please rate/comment.
Thanks!
3026 Downloads
Cupboard with light
Cupboard with light
4380 Downloads
CUSTOM INDUSTRIAL SHELVES WITH HARDWARE ACCESSORIES
REVIT VERSION 2022
ALL HARDWARE AND SHELVING ACCESSORIES ARE EDITABLE TO YOUR NEEDS. YOU MAY MOVE THEM ANY WHERE YOU NEED IT
1935 Downloads
Diamond Shelf
Diamond Shelf
First time uploading a component modelled by me.
This is a non parametric family, wall based but the elevation height can be edited.
I saw the shelf on Etsy and decided to model it so you can purchase it there if you want.  Enjoy💕
1255 Downloads
Display Case Cherry wood
DISPLAY CASE
4 Stars from 1 Votes
9861 Downloads
Egg Crate Shelf
Egg Crate Shelf
Product Version: Revit Structure 2013
1332 Downloads
Elfa Storage system
Elfa Storage system
Download: http://bimobject.com/en/elfa/product/inred_40_642
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-app
Basic elfa unit for clothing storage.
Suitable for housing projects both behind sliding doors as well as in Walk In closets. Solution based on our unique elfa Hanging System for high flexibility, easy and fast installation.
Long hang standards to ensure full future flexibility with both specific add on solutions or completely individual add on component by component made by the final end user.
Place add on solution (bedroom and/or linen solutions) at the far left or far rigth side if used together with sliding doors.
Use Clearance function to ensure correct depth for best practical function.
If multiple sections are used, the second section from the left is adjusted in width in order to match total width. Please note that pull-out functions can not be adjusted in width. The actual adjustment of products is to be made by installer (cutting closet rod and wire shelf).
3 Stars from 9 Votes
13830 Downloads
elipse louvers wooden shelf
1467 Downloads
Entertainment Center - Multi-Media
Modern Entertainment Center for Multi-Media Equipment
Solid to Void Geometry with Vert Alum Rods and Glass Shelves - Main Unit is made of Blue Plastic Laminate
2854 Downloads
EXPEDIT TV Shelving
EXPEDIT TV Shelving
EXPEDIT TV Shelving
4955 Downloads
Ikea Expedit 4x4 Shelf
9367 Downloads
Ikea Expedit 5x5 Shelf
3 Stars from 3 Votes
10950 Downloads
Ikea Wall Shelf
Ikea Wall Shelf
EKBY JÄRPEN/ EKBY STILIG
Wall shelf, white
Product dimensions
Width: 46 7/8 "Depth: 11 "Height: 13 3/8 "
Width: 119 cmDepth: 28 cmHeight: 34 cm
2030 Downloads
Jointed Wall Shelf
Jointed Wall Shelf
Unofficial Model: Industry West Jointed Wall Shelf.
https://industrywest.com/collections/in-stock
3.5 Stars from 3 Votes
12807 Downloads
Linebased Shelve x* cm
Linebased objekt changes length by drawing
1984 Downloads
Linebased Shelve x*120 cm
This families are linebased they automaticaly change their length by drawing them.
1257 Downloads
Linebased Shelve x*80 cm
2 Stars from 1 Votes
3803 Downloads
Locker Room Bench with Shelving Array
Line Based Generic Model with arrays that automatically adjust brackets for bench, shelving and number of hooks based on max_spacing. Visibility control for shelving and bench.
15870 Downloads
9253 Downloads
Low cupboard
Low cupboard
3891 Downloads
Media Center oak
Media Center oak
Unit is 154" long, 83" tall, 24" deep
2188 Downloads
Page generation time: 0.6405
