53 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
A Room tag displaying department name
This is the modified version of original room tag.
5 Stars from 3 Votes
10675 Downloads
NCS Room Tag with basic Finish Info
NCS Room tag that has a type that includes the room basic finish information
3067 Downloads
OCCUPANCY LOAD SCHEDULE, CODE COMPLIANCE PLAN
This is the finished Facility Occupancy Load Schedule and Egress Plan. This is automated to calculate the occupant load based on the type of area then use that to calculate occupant load.
There are 2 tags. 1 for rooms, 1 for egress doors.
There are 4 schedules
1.      DOOR EGRESS SCHEDULE
2.      FACILITY OCCUPANCY SCHEDULE
3.      ROOM OCCUPANCY COMPARE SCHEDULE
4.      SPACE OCCUPANCY CLASSIFICATION
There is one sample Model.
Steps:
1.      Copy the schedules and tags to your current project.
2.      Open the Room occupancy compare schedule
3.      Select what type of area you see fit.
4.      Type in 0 sf for “NON CALCULATED ROOM AREA” to calculate occupants
5.      Manually type in tag value to match calculation to populate the room tag.
6.      Place the facility schedule on the code plan sheet.
7.      Place the Door egress schedule on the sheet too.
8.      Place all your room tags
9.      Place your egress door tags on 1 exit way door only per egress area
10.   Make a note of how you want to number your egress areas. ( I usually go clockwise from upper left to lower right)
11.   Fill in the Egress area for each room in the properties field. ( You can multiple select rooms at the same time and type in the value for all at once, use your filter)
12.   The Facility Schedule will populate.
13.   Type in the Occupant value to the Door egress schedule. Make sure they match. Hide Door egress schedule.
You’re done. Or pretty close J #JustinDesigns3D JustinDesigns3D@Gmail.com
Product Version: Unknown
3842 Downloads
Room Tag
Room Tag
3483 Downloads
Room Tag
Room Tag
Fully Parametric room tag that shows wall finish, base finish, floor finish and ceiling finish
4568 Downloads
Room Tag
Room Tag
A simple room tag
1412 Downloads
Room tag - With Finish symbols
Those symbols are used to show the different finish materials. This sample was defined with 04 finish types: Floor, Wall, Celling and Base moulding.
4 Stars from 5 Votes
4376 Downloads
Room Tag Package
Room Tag Package
Modeled in Revit 2024 to Malaysian Standards
84 Downloads
Page 1 of 1 |
Page generation time: 1.4944
