1 Seat Sofa |
Product Version: Unknown
39948 Downloads
Simple armchair made from an extrusion and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. The beam is offset to counter line clipping through the table top surface. |
No rating |
1938 Downloads
3' wide, modern 3d chair, simple
looks good in plan, elevation, 3d |
2955 Downloads
Version: Rac2015
Please rate.
Thanks |
7681 Downloads
Product Version: Revit Structure 2009
31731 Downloads
Aeron Work Chair |
Product Version: Revit Building 9.1
50398 Downloads
red and white sphere chair |
18004 Downloads
fabric sofa |
50804 Downloads
14142 Downloads
Design by Hans Streitner Architekten, HSA 1985 |
No rating |
947 Downloads
Arm Chair |
No rating |
3022 Downloads
Not Parametric |
13186 Downloads
I have taken a manufacturers family - redrew it - so every curve is tangentle to other planes - hence with lines on - no lines between formed surfaces. This is how drawing should be. When 3D view set at Scale 1:1 - therefore no thick line work. In this instance no linework turned on anyways.
Manufactured items in sheetmetal, plastics, timber etc, it is vare rare to have a sharp corner on it. All planes should have a radiused chamfer - just look around your office - hard to find two surfaces coming together with sharp edge.
Have posted this here solely to assist others on how to draw and also how to display.
To many rubbish families posted here - learn and create each one better than the last one.
Any comments - feel free - |
9452 Downloads
Arm Chair Vime |
No rating |
10466 Downloads
Parameters for materials |
No rating |
11177 Downloads
19477 Downloads
armchair |
22681 Downloads
No rating |
4559 Downloads
10284 Downloads
Hi, I have been modelling a couple of objects that I thought I could share with the rest of you.
I drew it in revit 2021, I can export it into an odler version, but I don't have much faith in my skills to do it properly and keep it's materials.
No rating |
1287 Downloads
13481 Downloads
20250 Downloads
19796 Downloads
Drawn in revit 2021 |
No rating |
1694 Downloads
No rating |
1724 Downloads
Nice detailed single seated armchair for your use.
Check out my profile for other families to use!
armchair , chair , side table , table , lamp , light , sofa , seating , furniture , furnishings |
6539 Downloads
No rating |
1377 Downloads
Materials and Width parametric Chair |
3476 Downloads
Materials can be changed. |
No rating |
14458 Downloads
This chair is based on the PotteryBarn Benton Leather Club Armchair (shown in the image).
The back cushion isn't as smooth as I would like it, but it's workable, especially since there aren't many club chairs on any of the download sites.
There are no size parameters, since they are all fixed per the manufacturer. |
28487 Downloads
