49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
Concealed Roller Shade
Adjustable length roller shade w/ on/off shade and adjustable shade length.
11"x7" box w/ blackout shade AND transparent shade
5 Stars from 2 Votes
5278 Downloads
Cubicle Curtain Track - Adjustable
Right angled curtain track. Length, Width, Turning radius are adjustable.
4.5 Stars from 2 Votes
6617 Downloads
Cubicle Curtain Track - Straight Run
For healthcare use.  This will show in plan and RCP a path for the curtain track and a squiggle for the curtain.  In section and elevation, it has representations for those too.  Any comments on how to improve or suggestions for fixing some of the bugs are much appreciated.
9732 Downloads
Curtains
Curtains
Fully Parametric curtains with type settings for height, width, drop, materials.
5 Stars from 10 Votes
48786 Downloads
Curtains - Parametric
An unnecessarily parametric curtain family. This was more of an exercise as opposed to something practical.
The curtains can be parametrically opened and closed through a slider in plan view. In order to do this it took calculous, trigonometry, and numerical methods to pull off. It is a little computationally heavy on the model.
Parameters include:
Materials, Curtain length/width/thickness, rod length/diameter, wall offset, grommet diameter/spacing, left/right/double curtains.
5 Stars from 6 Votes
Product Version: Unknown
18917 Downloads
Parameters include:
3.5 Stars from 3 Votes
8269 Downloads
Curtains and Valance
These curtains are about 14' tall and 8' wide. Should be simple to change the material. If you have issues, comment below and I'll see what I can do to help. First upload, so I hope it works!
13719 Downloads
CURTAIN_70" high
CURTAIN_70" high
I added a material for fabric which you can change. But this is non-parametric curtain.
4.5 Stars from 12 Votes
39201 Downloads
Cushion / Euro Pillow
Pillow or cushion, kind of boxy. Materials are editable
1 Stars from 1 Votes
36945 Downloads
decor 150 vertical blind
3 Stars from 2 Votes
2139 Downloads
decor 160 mono vertical blind
1435 Downloads
Parametric Curtain
Parametric Curtain
First Upload!
A Parametric Curtain - Ceiling-Type Object
You can change the curtain width, height, its distance from the ceiling, the rod length and location. Curtain and Rod materials are parametric. It'll look funny if you make it too small or too big - it's ideal at around 5'-0" in width.
Tags: Curtain, Blind, Shade, Drape, Window Treatment
3.5 Stars from 19 Votes
125525 Downloads
Parametric Window Blinds
These blinds are fully parametric. You can adjust the height and width as well as the angle and depth of the blinds.
All parameters are instance based.
Regenerates much quicker than other blinds families.
5 Stars from 4 Votes
12143 Downloads
Window Blinds, Lamellae
Parametric set of window blinds / curtains / lamellae. The lamellae can be set to be set to span the entire window or be set to the side, it can be rotated between two limits of degrees ensuring you cannot overclose the lamellae. You can set the width and the height of the blinds to your custom size.
Hope you like it.
9922 Downloads
Page 1 of 1 |
Page generation time: 16.2194
