54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
Product Version: Unknown
353 Downloads
2 Stepped isolated Footing
1351 Downloads
21 ft X 40 ft swimming pool
1 Stars from 1 Votes
Product Version: Revit Building 8
6851 Downloads
3 Stepped isolated Footing
394 Downloads
3/4" chamfered curb
3/4" chamfered curb
3/4" chamfered curb with adjustable width and height
Product Version: Revit Structure 2009
3957 Downloads
30" Diameter Geopier
1412 Downloads
4 Stepped isolated Footing
224 Downloads
Adjustable Pier and Footing Pad
6271 Downloads
Column Footing Conc.
Parametric Footing for variable size thickness & ecentricity
3654 Downloads
Conc Rectangular Column with Isolated Footing
Fully parametric for column & footing size along with variable thickness of footing & ecenricity.
4291 Downloads
Concrete Drilled Pier
This is a Concrete Drilled Pier with an optional bell.
5 Stars from 3 Votes
4227 Downloads
Concrete Driveway Apron
Level based model component of a concrete driveway apron, to be placed at the threshhold of an overhead garage door leading to the driveway. Length is adjustable, dimensions of profile can be changed in type editor.
Created with Autodesk Revit 2023
263 Downloads
Concrete Pier Block
Concrete Pier Block
Revit 2018 Concrete Pier Block_parametric
1648 Downloads
Concrete Pier Footing
Fully parametric square concrete footing with square pier support and column straps.
Familt Category is 'Structural Columns' rather than 'Structural Footings' because when attaching a column to it, the column would attch to the top of the strap elevation rather than the pier bearing surface if categorized as a footing...
4 Stars from 1 Votes
5269 Downloads
Contriver Footing Trapezoidal
Fully parametric column footing with provision for eccentricity of column to footing. All parameters are adjustable
2182 Downloads
curved wall foundation
I defined a wall foundation family for a curved wall
1199 Downloads
Door opening in wall with dashed lines
Door opening in wall with dashed lines in plan view
Parameters are in french
10215 Downloads
Drilled Pier
Drilled Pier
Adjustable Drilled Pier
Change Length, Diameter and lower height of footing as a type property to allow for slab etc
4 Stars from 2 Votes
Product Version: Revit Structure 2008
6828 Downloads
Drilled Pier with Cap
Drilled pier family allows adjustment of cap edge distance relative to piers. Pier diameter, length, & minimum embed into cap can be adjusted
3983 Downloads
Footing and Big Foot Pad
adjustable Sono Tube and Big Foot Pad
2085 Downloads
Footing-Rectangular w Circular Pier
This is a typical rectangular footing with circular (think sonotube) pier. Width, Length, Thickness, Pier height, Pier diameter are parametric. Pier is centered.
3 Stars from 8 Votes
4706 Downloads
foundation concrete link
3.5 Stars from 126 Votes
170 Downloads
Foundation Control Cabinet
Foundation control cabinet
Fully parametric family
Visibility parameters, dimensions and shared parameters for formwork and concrete quantities
48 Downloads
Foundation Type curse
One of the foundations that are in Indonesia
3.5 Stars from 5 Votes
3967 Downloads
Helical Piling
Helical Piling
Steel helical piling
1493 Downloads
Hill Road's RR Dry Stone masonary Retaining Wall
This is a standard design for R.R.Dry Stone masonary Retaining wall to support the hill roads. As normally the maximum length of hill roads are supported by these dry walls which do not use any mortar for masonary, to control the cost. Filling behind the wall has also modelled for explaining purpose, which may be removed.
170 Downloads
Isolated Footing
Isolated Footing
Isolated Footing Family
4.5 Stars from 4 Votes
7887 Downloads
Isolated Footing
Isolated Footing
Parametric Isolated Footing with sub-structure
7365 Downloads
Isolated Footong with Base & 2 Pedestals
Adjustable shape trapozoidal or unithick Isolated footing for str. columns. with Base & 2 Varable Pedestals  fully parametric Ver 2015 by Er. L.J.Upadhyay.
5 Stars from 2 Votes
1629 Downloads
Isolated Trapozoidal Adj Footing
Cast in place Adjustable shape trapozoidal Isolated footing for columns. Varable pedestal base & fully parametric Ver 2015 by L.J.Upadhyay.
2059 Downloads
Page generation time: 0.8447
