(3)2x4 |
Product Version: Unknown
7406 Downloads
(4)2x4 |
3954 Downloads
(5)2x4 |
No rating |
4025 Downloads
Fully Parametric |
14577 Downloads
Fully Parametric |
8749 Downloads
Typical Gable-end Truss w/ top-chord offset to allow for rake extensions. No webs shown (Manufacturer designs that not architects). Variable chord sizing, slope, bearing length & overhang length. See also "06 - Truss - Fink- No Web". |
2513 Downloads
Typical Truss w/out webbing showing (Manufacturer designs that not architects). Variable slope, chord size, bearing length & overhang length. See also "06 - Truss - Fink Gable - No Web" |
No rating |
2255 Downloads
10 equal part with different size cord and web |
Product Version: Revit Structure 2012
9224 Downloads
12 equal part with different size cord and web |
7632 Downloads
Fully Parametric Pratt Truss with Vertical End Members. |
Product Version: Revit Structure 2014
15356 Downloads
250 Grd CHS Beam |
7598 Downloads
These is a 2d Post Tension Cable call out and symbols. Below is a list of the files that are used with it. Please let me know if you see something that would make these better.
PT - Post Tension.rfa is the main file. It's the one will use to place your cable. I have 4 Family Types setup in it. It can be easily changed up to do what ever you need.
PT - Force Tag.rfa is the tag that you need to call out the Force on that Cable. There are 2 types setup here. one for Kips Per FT and one for Total Kips.
PT - Text is used to show the height of the cable. PT-text are just symbols you can place them were ever you need them.
PT - Offset End. I made it up so if i need to work around an opening in the slab. It's still in Beta. It will get you around the opening but you are going to have to work for it. I'm hoping to think of a better way to do it later on.
You will also need to add two Parameters to your Shared Parameters. One called FORCE for Discipline Structural and Type of Parameter Force. The other is FORCE PER FOOT for Discipline Structural and Type of Parameter Linear Force. |
Product Version: Revit Structure 2013
1533 Downloads
Parametric 3/4"Ø A325 Heavy Hex Bolt. Grip is an instance paramter. Based on grip, formulas determine bolt length and weight (shared parameters) which allow for scheduling and more importantly, bolt list with bolt lengths. Parametric void to cut hosted framing. Bolt visibility paramters are also in place plus an instance parameter for a welded nut (moves the washer to the bolt head side of grip) Based on Portland Bolt specs. Revit 2012. |
15798 Downloads
350 Grd Gal Tube CHS |
4508 Downloads
350 Grd SHS |
6361 Downloads
350 Grd Ultra Pipe CHS |
4396 Downloads
3D Beam for Framing Plans.
Slopeable and you can add framing tags to represent the beam on the framing plan. Shared element so you can actually create a Framing Member Schedule.
Fully Parametric. |
No rating |
1974 Downloads
4874 Downloads
4 equal part with different size cord and web |
No rating |
6078 Downloads
450 Grd SHS |
3911 Downloads
Parametric instance of 8"x48" hollow core precast plank. |
No rating |
Product Version: Revit Building 9
5438 Downloads
Parametric A325 Heavy Hex Bolt Assembly. This bolt is set to 3/4"Ø by default, but also contains 1/2"Ø, 5/8"Ø, 7/8"Ø, 1"Ø, 1-1/4"Ø & 1-1/2"Ø sizes. Based on Portland Bolt Specs. Revit 2012. |
11161 Downloads
Engineered floor truss that will conform to the length of the structure. |
4756 Downloads
Jack or Hip Truss with adjustable top chord |
6614 Downloads
Adjustable wind brace portal frame for Pre-engineered Metal Buildings. |
4977 Downloads
A fully adjustable metal building frame with web stiffeners and baseplates |
No rating |
7572 Downloads
Fully adjustable metal building rigid frame with optional eave extensions. |
4681 Downloads
No rating |
1320 Downloads
Product Version: Revit MEP 2010
2674 Downloads
No rating |
1491 Downloads
