2 lane parametric Parking Ramp |
Product Version: Unknown
14255 Downloads
3460 Downloads
3/4" chamfered curb, Adjustable width and height |
Product Version: Revit Structure 2009
8746 Downloads
Created in RAC 2009 using slabs w/6" Variable thickness. |
8127 Downloads
Parking stall that will host itself to sloped objects (like sloped double tees in my case). |
2388 Downloads
Post Sign |
3013 Downloads
Adjustable sign |
8340 Downloads
2418 Downloads
ADA parking space |
No rating |
7500 Downloads
ADA parking space |
14988 Downloads
ADA Signage |
No rating |
2535 Downloads
This fully parametric handicap accesible ramp with flared sides is based on a 1:12 slope for the ramp and 1:10 slope for the flared sides. Adjust the curb height and the ramp automatically calculates the depth and the width of the flares. The ramp width itself is expandable and the material is changeable. You can recalculate the slope ratios to meet your local codes. Enjoy! |
Product Version: Revit Building 8
20319 Downloads
AGRV_PRKG_Car-AD-Dropoff_無障礙汽車下車區
Accessible Design Parking Dropoff and strip with DIM & Material parameters and dimension Guide
All size is basic on Taiwan architecture regulation.
Visit our website AgileRevit.com for more families |
No rating |
610 Downloads
AGRV_PRKG_Car-AD_無障礙汽車停車位
Accessible Design Parking Space and strip with DIM & Material parameters and dimension Guide
I use shared parameter so you can easily count them using schedule.
No rating |
336 Downloads
AGRV_PRKG_Car_汽車停車位
Parking space and strip with DIM & Material parameters and dimension Guide
No rating |
645 Downloads
AGRV_PRKG_Motorcycle-AD_無障礙機車停車位
Accessible Design Motorcycle Parking Space and strip with DIM & Material parameters and dimension Guide
No rating |
290 Downloads
25' tall flag GO USA!!!!! |
4197 Downloads
Two options: with or without handrail.
Note that the one without handrail has a small extrusion running under its base, that is just a trick to make it work. Just make sure you hide it in section.
Revit 2013 |
8249 Downloads
PLEASE RATE! Automated Rotary PArking in REVIT 2014 version |
3525 Downloads
8911 Downloads
Bolardo existente en las calles de Madrid |
Product Version: Revit MEP 2019
169 Downloads
182 Downloads
No rating |
376 Downloads
No rating |
326 Downloads
a model of a Caddy CTS from Max. It's a pretty big poly count so beware of when you import it. I made the body color parametric so you can change it to whatever color you wish. Check the object styles, import section to change it. |
Product Version: Revit Building 9.1
15951 Downloads
This stall is for a single or double accessible stall for California. Includes Van Accessible (8') as well as standard (5') |
9693 Downloads
Car parking roof tent in fabric finish for 2 cars slot on 1 column support |
6148 Downloads
This is a simple concrete apron I made. Used for ADA access to sidewalks from the street and the like. Nothing special about it. I think it is parametric. I got tired of my void forms not working so i made this.
This is a face based family.
Let me know if this doesn't work or how it can be impoved. This is my first upload.
Thanks
No rating |
954 Downloads
Thanks
No rating |
281 Downloads
I took the gutter curb here and stripped off the horizontal elements. Radius works the same |
No rating |
4760 Downloads
