9646 Downloads
9337 Downloads
8597 Downloads
No rating |
4843 Downloads
3959 Downloads
7346 Downloads
Military Humvee made in Revit. Part of my 3d objects collection at www.3dentourage.com
Made by Jeff Rath |
2494 Downloads
1950-1967 Volswagen Type 2 (T1) Van - This is a special request so i hope its what you needed. Set up to change the color of the Roof, Bumpers, Window trim, and two tone body colors. You can also change the interior floors, and two tone interior, as well as the window colors: Rear, sides, doors and windshield, including two tone wheels and even the logo on the front. All materials are listed under VW T1 for easy location and changing of materials.
NOTE: AutoCAD file to large to download, sorry
FILE TYPE: Revit 2012 64 Bit |
28078 Downloads
I made everything myself, except for the engine, that credit goes to docvingoldman2708 - who did an amazing job
All materials should be able to be rendered however you like, just ungroup the object and have at it.
Enjoy |
2249 Downloads
Ferrari F-40 Features 3 parametrical functions “Handle & Tires movement”, “Opening & Closing the Door”, “Shifting Gears”. Made by Revit(2010-2011). |
23459 Downloads
Model adapted from 40' cargo container posted by cpercer. I did a rush job on it and a few pieces might be misaligned. Good luck with your projects! |
No rating |
Product Version: Unknown
5134 Downloads
2012 Audi A8 - All materials are listed under AUDI A8 for easy location and changing of materials.
Running lights, Rear running lights and headlights can be turned off by changing the material to Chrome. The day time running lights and Rear running lights are illuminated to show the effect. if you want the headlights on change the material to match the others. Pay close attention to their custom illumination settings.
NOTE: Autocad file to large to download
FILE TYPE: Revit 2012 64 bit |
31562 Downloads
2012 BMW 750Li Sedan - All materials are listed under BMW 750Li for easy location and changing of materials. If you want the lights turned off simply locate the materials listed under BMW 750Li - Lights and change each material to Chrome.
NOTE: AutoCad file to large to download
FILE TYPE: 2012 64 bit |
38276 Downloads
2012 BMW Z4 Convertible - All materials are listed under BMW Z4 for easy location and changing of materials. Including lights, two tone dashboard, two tone interior, body color, wheels etc.
NOTE: AutoCAD file to large to upload, sorry
18990 Downloads
2012 Mercedes SL R231 - With Parametric Settings: Roof Up or Down, Windows Up or Down. Defualt settings are with both set to the up position and the lights off. If you want to turn the lights one you'll need to change the appropriate listed light materials (fog, headlight, tail lights) to a Luminated Glass. Sorry it was a setting, but made the file to large to download. All materials are listed under SL R231 for easy location and changing.
21222 Downloads
2012 - Porsche 911 Carrera S - All materials are listed under 911 CARRERA S for easy location and changing of materials. if you want to turn the lights off. locate the materials listed under "Lights" and change the materails to 911 CARRERA S - LIGHTS - OFF.
15299 Downloads
2013 Dodge SRT Viper GTS - All materials are listed under 2013 VIPER for easy changing fo materials and colors.
FILE TYPE: Revit 2012 - 64bit |
7531 Downloads
2013 Boss Mustang - All materials are listed under BOSS for easy location and changing of colors and materials including racing stripes, interior, body and wheel colors. I didn't like the stock black fin, so i changed it to spoiler I liked. Other then that its a stock BOSS.
FILE TYPE: Revit 2012 64bit
UDATE CONTAINS: Default Color, Running lights, and Headlight materials, Front grill striping....NOTE: If you want the lights off simply change the layers to chrome to maintain an off appearance. |
22014 Downloads
Citroen 2CV. Not RPC. Pure revit. Parameters for materials. |
5605 Downloads
2d bicycle for use in plans instead of a messy 3d model |
4627 Downloads
2D Lokcheed U-2 Plane |
Product Version: Revit MEP 2008
11204 Downloads
2d Motorbike for use in plans over the place of a messy 3d mesh |
2223 Downloads
3 Cell variable span & height Box Bridge fully parametric |
No rating |
1739 Downloads
350 ton crane. Approx. 63' x 10' with out riggers up. |
Product Version: Revit Structure 2012
9473 Downloads
A 100% Revit content off road jeep. Made by Jeff Rath. See my web site www.3dentourage.com
3d vehicle
https://www.facebook.com/3dentourage/?fref=ts |
29469 Downloads
Part Autocad and part Revit. Re-engineered to show fewer lines in wire frame and Hidden Line views. Render ready. also looks good in shaded views and hidden line views.
www.3dentourage.com
Jeff Rath |
7429 Downloads
100% Revit content. 3d road grader construction vehicle. From my collection at www.3dentourage.com Made by Jeff Rath
8028 Downloads
4 WHEELER |
7520 Downloads
Old Chevy Caprice with 30" Rims, wowza!!!
Enjoy!!! |
4442 Downloads
8 Man Crew Boat |
5066 Downloads
