80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
Classical Baluster
Classical Baluster
4350 Downloads
Crash Rail
Crash Rail
my first family from scratch; length can be changed. Based loosely on the CS Acrovyn Crash Rail
Product Version: Unknown
1338 Downloads
Deck Post
This is a baluster family to help create an exterior deck railing that includes a built in seat. The dimensions are adjustable for seat height & depth. The thickness can be modified and the width of the post to the top rail. The tricky part is adjusting the horizatonal railings that form the seat back. The angle is hard coded to 15deg.
3.5 Stars from 3 Votes
3251 Downloads
Guard Rail Profile
Guard Rail Profile
Guard rail profile for use with the railing tool.
5 Stars from 2 Votes
4313 Downloads
hand rail Steel Tube
388 Downloads
Hand Rail-Round-Section.rfa
1 Stars from 1 Votes
2617 Downloads
1345 Downloads
1174 Downloads
Iron fence
Iron fence
We use to have this kind of fence, especially for our dogs husky is verry effective. I've modelled and even welded one of our fence for the dogs. Easy to model and execute.
4 Stars from 15 Votes
57285 Downloads
Prestige Railing Profile
This is a wide rail profile that can be loaded in to your stair or guardrailings.  The material is parametric.
4083 Downloads
railing glass
railing glass
parametric railing glass
barandilla de vidrio de dos tipos, espero les sirva es estilo parametrico
4 Stars from 23 Votes
63832 Downloads
Railling - Adaptive Railing with 3 axis
A component done with the Adaptive Railing Family File with 3 axis structure. To be add preferably on the 3D window, on TOP VIEW and arrange it on a floor window.
Pick the spot of the axis by it's sequence. Or add the sequence of new points in the family file.
Diameter of the railing - 50mm; circular form
3057 Downloads
Tension Cable Double Top Railing
Just copy and paste the railing into your project. If you do need to edit the Sizing of members they are parametric.
Hope it helps,
smh
10175 Downloads
UOT - Kamel - Railing - 50 mm
UOT - Kamel - Railing - 50 mm ... Building and Construction Engineering Department ... University of Technology ... Baghdad, Iraq ...
689 Downloads
Page 1 of 1 |
Page generation time: 0.3989
