79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
A Room tag displaying department name
This is the modified version of original room tag.
5 Stars from 3 Votes
10643 Downloads
addendum symbol
addendum symbol
addendum symbol
Product Version: Unknown
1479 Downloads
Beam System Tag
Beam System Tag
1167 Downloads
Beam System Tag
Beam System Tag
582 Downloads
Braced Panel Tag
Braced Panel Tag
Braced Panel Tag
1110 Downloads
Bubbles
Bubbles
If you are tired of simple/no fun bubbles...
Product Version: Revit Building 9
2162 Downloads
CASEWORK TAG FAVORITE
Annotation for casework, tested, vetted, works well
3812 Downloads
Ceiling Tag
Ceiling Tag
Basic Ceiling Tag, just the "Height Offset From Level" and A.F.F.  text
1053 Downloads
Door Rectangular Tag (Greek Family)
3 Stars from 2 Votes
2305 Downloads
Door Tag
Door Tag
Circle with Opening Number and Window Number (Mark and Type Mark)
3745 Downloads
Door Tag
Door Tag
NOTE:
Browse thru all the various Tags to get the one you want.
Door Tag with Project Unit Dimensions (instead of Symbols) suitable for Residential Contractor Plans. The "45" tags are for Doors in Angled walls. For larger doors (Garage) you can use the "FEET" type tag.
4803 Downloads
Double Line Room Tag
This is a double line room tag.
1 Stars from 1 Votes
7318 Downloads
Egress Door Tag
Egress Door Tag
Door tag for showing egress width
3.5 Stars from 2 Votes
3006 Downloads
Egress Door Tag
Egress Door Tag
Shows the following:
  1. Mark (auto)
  2. Width (auto in inches)
  3. Occupancy count (manual)
  4. Required Width (auto in inches)
You must link in Shared Parameters into project and create parameters for used wall types (similar to example.)
2.5 Stars from 3 Votes
2139 Downloads
Egress Width Tag with Direction
Egress Width Tag; Calculates the required width for doors and stairs based on Occupant loads. Also, has four options for Direction of Egress. Enter the Occupant Load and the Code required width per person and it will show the required total width. Instance parameter, for each separate location. Includes a place holder for Actual Width.
Product Version: Revit Architecture 2019
606 Downloads
Elevation Tag - 8 Interior Views
2.5 Stars from 2 Votes
3076 Downloads
Etiqueta para Puerta
Etiqueta para indicar en puertas el Ancho de vano y la altura del Dintel de una puerta cualquiera colocada en Revit Architecture 2012
1599 Downloads
Identificador de Janela Norma NBR 6492
Window tag Brazilian standard NBR-6492
2466 Downloads
Identificador de Porta Norma NBR 6492
Door tag Brazilian standard NBR-6492
1 Stars from 2 Votes
2949 Downloads
Keynote - Octagon
Keynote - Octagon
Keynote - Octagon
2.5 Stars from 6 Votes
1739 Downloads
Keynote - Pentagon
Keynote - Pentagon
Keynote - Pentagon
1046 Downloads
Modifiable Finish Tag
this finish tag includes finish information for floor, base and wall. Each can be modified by instance and can be placed on a finish plan
4665 Downloads
NCS 4.0 Exterior Elevation tag
This is a NCS 4.0 Exterior Elevation tag with the correct 5/8" dia circle built with Revit 2011
10234 Downloads
NCS 4.0 Interior elevation tag
This is a NCS 4.0 Interior Elevation tag with the correct 5/8" dia circle built with Revit 2011
7443 Downloads
NCS Door Tag
NCS Door Tag
This is a door tag based off of NCS 3.1 where the Door number is Parallel to the door leaf.
10690 Downloads
NCS Room Tag with basic Finish Info
NCS Room tag that has a type that includes the room basic finish information
3060 Downloads
note block tag with joist span
Insert as symbol to indicate structural framing span direction and member tag, populate a note block with framing information (e.g. 2x10@16")
Set length of arrow as actual span.
Set view scale in feet/in (1/4"=1'-0" represented as scale = 4'-0", 3/16"=1'-0"  as 3'-4")
392 Downloads
OCCUPANCY LOAD SCHEDULE, CODE COMPLIANCE PLAN
This is the finished Facility Occupancy Load Schedule and Egress Plan. This is automated to calculate the occupant load based on the type of area then use that to calculate occupant load.
There are 2 tags. 1 for rooms, 1 for egress doors.
There are 4 schedules
1.      DOOR EGRESS SCHEDULE
2.      FACILITY OCCUPANCY SCHEDULE
3.      ROOM OCCUPANCY COMPARE SCHEDULE
4.      SPACE OCCUPANCY CLASSIFICATION
There is one sample Model.
Steps:
1.      Copy the schedules and tags to your current project.
2.      Open the Room occupancy compare schedule
3.      Select what type of area you see fit.
4.      Type in 0 sf for “NON CALCULATED ROOM AREA” to calculate occupants
5.      Manually type in tag value to match calculation to populate the room tag.
6.      Place the facility schedule on the code plan sheet.
7.      Place the Door egress schedule on the sheet too.
8.      Place all your room tags
9.      Place your egress door tags on 1 exit way door only per egress area
10.   Make a note of how you want to number your egress areas. ( I usually go clockwise from upper left to lower right)
11.   Fill in the Egress area for each room in the properties field. ( You can multiple select rooms at the same time and type in the value for all at once, use your filter)
12.   The Facility Schedule will populate.
13.   Type in the Occupant value to the Door egress schedule. Make sure they match. Hide Door egress schedule.
You’re done. Or pretty close J #JustinDesigns3D JustinDesigns3D@Gmail.com
3829 Downloads
Octagon Keynote
Octagon Keynote
Octagon Keynote
Product Version: Revit Building 5.1
870 Downloads
Octagon w/ Trim
Octagon w/ Trim
A revit 7 version of the popular octagonal shaped window
1.5 Stars from 3 Votes
976 Downloads
Page generation time: 0.6237
