78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 6 | 1 | 2 | 3 | 4 | 5 Next >>
2-Piece, Full Port, Brass Ball Valves - FBV-3C
Series FBV-3C & FBVS-3C 2-Piece, Full Port, Brass Ball Valves are used in commercial and industrial applications for a full range of liquids and gases. They feature a bottom-loaded blowout-proof stem, virgin PTFE seats, thrust washer, and adjustable stem packing gland, stem packing nut, chrome plated brass ball, brass adapter, and steel handle. Model FBV-3C has threaded end connections. Model FBV-3C-TH has tee handle with threaded and solder connections. Model FBVS-3C has solder end connections. Pressure Rating for 1/4 in. ‒ 2 in. (8 ‒ 50mm) is 600psi WOG and 150psi WSP. 2 1/2 in. to 4 in. (35 ‒ 100mm) is 400psi WOG and 125psi WSP.
1252 Downloads
2-Piece, Full Port, Brass Ball Valves - FBV-4 Series
Series FBV-4 & FBVS-4 2-Piece, Full Port, Brass Ball Valves are used in residential and commercial applications for a full range of liquids and gases. They feature a bottom-loaded blowout-proof stem, chrome plated brass ball, brass adapter, and steel handle. Seats, thrust washer, and adjustable stem packing seal are virgin PTFE. Model FBV-4 has threaded end connections and is NSF & CSA approved. Model FBVS-4 has solder end connections and is NSF approved. Pressure Rating for 1/4 in. ‒ 2 in. (8 ‒ 50mm) is 600psi WOG and 150psi WSP. 2 1/2 in. ‒ 3 in. (65‒80mm) is 400psi WOG and 125psi WSP.
1261 Downloads
2-Piece, Full Port, Brass Ball Valves - LFFBV-4B
Series LFFBV-4B, LFFBVS-4B 2-Piece, Full Port, Brass Ball Valves are suitable for a full range of liquids and gases in residential and commercial applications. These valves feature an adjustable packing for longer service life, a bottom loaded blow-out proof stem for safety, a fluorocarbon elastomer stem O-ring to prevent stem leaking at installation, and are rated to 600psi WOG/150psi WSP 1⁄4"– 3".
687 Downloads
2-Piece, Full Port, Lead Free* Brass Ball Valves - LFFVC-3C-QC
Series LFFBV-3C-QC 2-Piece, Full Port, Lead Free* cast copper silicon alloy Ball Valves with Quick-Connect Technology are used in residential and commercial potable water applications. They feature a bottom-loaded blowout proof stem, virgin PTFE seats and thrust washer, adjustable packing gland, stem packing nut, chrome-plated brass ball adapter and steel handles. Comes with integral Quick-Connect inlet and outlet connections for fast installation on copper, CPVC, PEX, and PB pipe.
597 Downloads
2-Piece, Full Port, Lead Free* Brass Ball Valves with PEX Ends - LFFBV-PEX
Series LFFBV-PEX 2-Piece, Full Port, Lead Free* Brass Ball Valves with PEX Ends are designed for use in PEX piping systems. They feature brass PEX ASTM F-1807 end tailpieces for easy crimping into PEX piping systems, a Lead Free* brass body, chrome plated brass ball, virgin PTFE seats and stem packing, and Viton stem O-ring. Pressure Rating is 400psi WOG. Crimp connection rating is 160psi at 73°F (23°C).
368 Downloads
2-Piece, Full Port, Lead Free* Bronze Ball Valves - LFFBV
Series LFFBV 2-Piece, Full Port, Lead Free* Bronze Ball Valves comply with MSS-SP-110 and feature a blowout proof stem and virgin PTFE seats. The full port design ensures maximum flow capacity and minimal pressure drop. Lead Free* construction complies with Lead Free* installation requirements. Has threaded NPT end connections. Pressure Rating is 600psi WOG/150psi WSP for 1/4 in. – 2 in. (8 – 50mm) and 400psi WOG/125psi WSP 2 1/2 in. – 3 in. (65 – 80mm).
716 Downloads
2-Piece, Standard Port, Bronze Ball Valves - B6400 Series
Series B6400 2-Piece, Standard Port, Bronze Ball Valves are used in commercial and industrial applications for a full range of liquids and gases. It comes standard with actuator mounting pads and the port orifice ensures minimal pressure drop. Durafill seats, blowout proof pressure retaining stem, and chrome plated brass ball provide lasting service. Pressure Rating for 1/4 ‒ 2 in. (8 ‒ 50mm) is 600psi WOG (non-shock) and 150psi WSP. Rating for 2 1/2 in. ‒ 4 in. (65 ‒ 100mm) is 400psi WOG (non-shock) and 125psi WSP.
709 Downloads
6.6M High Galvanize Water Tank Frame
6.6m kamals high galvanize water tank frame for 2floor structure.
1118 Downloads
9.6M High Galvanize Water Tank Frame
9.6m kamals high galvanize water tank frame for 3floor structure.
2341 Downloads
A Fire Protection Water Tank
Parametric Fire Protection Water tank, with 2 Acess Hatches, Parametric for most things
5180 Downloads
adjustable downspout
4.5 Stars from 2 Votes
Product Version: Unknown
8587 Downloads
Ball Valve - 2-6 Inch - Modified - r17.rfa
Started with the Revit 2017 Out-Of-Box Ball Valve (Pipe Accessory) and added additional valve symbol as model lines so that the valve symbol still shows up in course detail level, even if the valve is rotated to the side of the pipe. You will need to disable the checkbox for "Symbol Top Visible" or the checkbox fo "Symbol End Visible" depending on how the valve is rotated. (I'm open to suggestions on better ways to do it, but ran out of time for now.)
Product Version: Revit MEP 2016
763 Downloads
Bath Taps in Chrome
Bath Taps in Chrome
Bath taps modelled on Cooke and Lewis taps.
Look nice in a bathroom render.
7222 Downloads
Butterfly Valve - 2-12 Inch.rfa
Product Version: Revit MEP 2009
2556 Downloads
1327 Downloads
Clean-out wall based
3 sizes but parametric, Jay R. Smith w/ SS cover
965 Downloads
Cleaning closet sink
1854 Downloads
Combination Ball Valve and Relief Valves - LFBRV
Series LFBRVM1 Combination Ball Valve and Relief Valve is an easy to install two-in-one device used to shut off the water supply to the water heater and to provide protection against excess water pressure caused by thermal expansion. Complies with Lead Free* installation requirements.
611 Downloads
308 Downloads
Compressed Air Terminal
Drip sight glass, Filter/Regulator and Oiler. Based on Nrogren Products. 3D fine and 2D medium and coarse representaion, 3/4" pipe connectors.
3.5 Stars from 3 Votes
Product Version: Revit MEP 2010
3339 Downloads
Conductor Head-Front.rfa
786 Downloads
Diaphragm Gas Meter AL800 - AL5000
Elster American Meter diaphragm gas meter commercial & industrial. 800 to 5,000 CFH
Product Version: Revit MEP 2019
432 Downloads
Double Check Detector Assemblies - 007DCDA
Series 007DCDA Double Check Detector Assemblies prevent the backflow of non-health hazard fire protection system substances from being pumped or siphoned into the potable water supply. They incorporate a meter to detect ground leaks and unauthorized illegal taps, greatly reducing annual water expenses. The compact epoxy coated cast iron unibody and modular check design facilitate simple and easy installation and maintenance. Maximum Working Pressure: 175psi (12.06 bar).
652 Downloads
Double Check Detector Assemblies, Cast Iron - 709DCDA Series
Series 709DCDA Double Check Detector Assemblies prevent backflow of non-health hazard fire protection system substances from being pumped or siphoned into the potable water supply. They incorporate a meter to detect ground leaks and unauthorized illegal taps, greatly reducing annual water expenses. Their compact epoxy coated cast iron unibody and modular check design facilitate simple and easy installation and maintenance. Maximum Working Pressure: 175psi (12.06 bar).
287 Downloads
Double Check Detector Assemblies, Stainless Steel - 757DCDA Series
Series 757DCDA, 757NDCDA Double Check Detector Assemblies prevent the backflow of pollutants that are objectionable but not toxic, from entering into the potable water supply. Compact housings consist of two independently operating tri-link check valves, two shutoff valves, and four test cocks. They feature a stainless steel housing and sleeve and are 70% lighter than traditional designs. Series 757, 757N is designed for non-health hazard applications and may be installed under continuous pressure service to protect against both backpressure and backsiphonage. This Series is used primarily on fire sprinkler lines when it is necessary to monitor unauthorized use of water. Maximum Working Pressure: 175psi (12.06 bar).
532 Downloads
Double Check Detector Assemblies, Stainless Steel - 774DCDA Series
Series 774DCDA Double Check Detector Assemblies prevent the backflow of fire protection system substances from being pumped or siphoned into the potable water supply. They have a compact construction and short lay length, ideal for retrofit installations. They feature a lightweight stainless steel body, thermoplastic and stainless steel check valves, and low head loss. Series 774DCDA can be installed in the horizontal or vertical flow-up positions. It is designed for installation on applications identified by local authorities as non-health hazard, such as on fire protection systems. Maximum Working Pressure: 175psi (12.06 bar).
562 Downloads
Double Check Valve Assemblies - 007-QT-S Series
Series 007 Double Check Valve Assemblies prevent the backflow of contaminated water into the potable water supply. They have a bronze (1/2 to 2 in.) body construction that is easy to maintain and service. Series 007 is ideal at referenced cross-connections identified as non-health hazard applications. Check with local inspection authorities for installation requirements. Maximum Working Pressure: 175psi (12.06 bar).
232 Downloads
Double Check Valve Assemblies - 009 Series
Series 009 Reduced Pressure Zone Assemblies prevent the reverse flow of polluted water from entering into the potable water supply due to backsiphonage and or backpressure. They have a bronze body construction (1/4 to 2 in.) or FDA approved epoxy coated cast iron (2 1/2 to 3 in.), two in-line independent check valves, replaceable check seats with an intermediate relief valve, and ball valve test cocks. Series 009 is ideal for protection of health hazard cross-connections or for containment at the service line entrance. Check with local water authorities for installation requirements. Maximum Working Pressure: 175psi (12.06 bar).
319 Downloads
Double Check Valve Assemblies Sizes - 757 / LF757 Series
Series 757 Double Check Valve Assemblies prevent the reverse flow of liquids in a plumbing system due to backpressure or backsiphonage where there is a non-health hazard. Compact design and lightweight stainless steel construction (70% lighter than traditional designs) makes installation easier and faster. For unmatched versatility, assemblies are available for horizontal, vertical, or N pattern installations while groove connections allow ease of installation and pipe alignment. Patented tri-link check assemblies are also designed for easy serviceability. A variety of shutoff valve options are offered.
771 Downloads
Double Check Valve Assemblies, Bronze - 719 Series
Series 719 Double Check Valve Assemblies are designed to protect drinking water supplies from dangerous cross-connections in accordance with national plumbing codes and water authority requirements. They have a bronze alloy body construction and chloramine resistant elastomers. Series 719 features a separate access, top-entry check valve design for ease of maintenance and is for use at referenced cross-connections in non-health hazard applications. Check with local inspection authorities for installation requirements. Maximum Working Pressure: 175psi (12.06 bar).
285 Downloads
Page generation time: 17.3939
