69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 6 | 1 | 2 | 3 | 4 | 5 Next >>
002-Kamals Electrical Power Transformer
Power Transformer designed carefully to siute your project.
1884 Downloads
1.5 MW Emergency Diesel Generator
Edited for particular job configuration with adjustable day tank option.
5 Stars from 3 Votes
Product Version: Revit MEP 2012
8163 Downloads
140 ft tall Wind Turbine
140 ft tall wind turbine with 100 ft blades
3 Stars from 2 Votes
8741 Downloads
200AMPSERVICEPANEL WMAST
4 Stars from 1 Votes
Product Version: Unknown
3998 Downloads
22 pedestal floor medgas-elec
Pedigo floor pedestal. Two sizes available.
1489 Downloads
3 BLADES WINDTURBINE
This Windturbine has been developped for a thesis about the use of the wind into the city. The aerofoil is designed to accerelate the wind into the turbine.
This content was created by David SERERO, CEO of SERERO Architectes, a compgny specialised in architecture.
Product Version: Revit Architecture 2019
287 Downloads
32 Track Mixer
This is a generic 32 track Mixing console with ballparked sizing
1881 Downloads
54" Lightning Rod
54" Lightning Rod
This is a rather detailed and fancy lightning rod.
5261 Downloads
650VA Single Phase Generator
File
386 Downloads
72 Watt Solar Panel
72 Watt Solar Panel
Work Plane Based Generic Model
Mounted on Rails and Based on GE Model
Nothing Special
3 Stars from 6 Votes
21087 Downloads
Ac unit - indoor vertical / Standing
3778 Downloads
Aerotecture 520H Wind Turbine
Aeroturbines are wind turbines designed for urban settings.  Invented by University of Illinois industrial design professor, Bil Becker, Aeroturbines are a new development in wind turbine technology.  Aeroturbines can be installed on existing rooftops or built into the architecture of new buildings to provide clean renewable electricity at its site of consumption.  Aeroturbines are uniquely suited to urban environments because they are:
  • Noise and vibration-free
  • Safe for birds
  • Able to utilize multi-directional and gusting winds
  • Self-regulating (no overspeed protection required)
  • Low maintenance
  • Made from low-cost and readily available materials
The structural features of the Aeroturbine allow for its easy integration into new or existing buildings: the modular/stackable cages are additive and can be mounted in a vertical, horizontal, or diagonal orientation.
4 Stars from 5 Votes
5221 Downloads
Back to the Future Flux Capacitor
Remake the Back to the Future Flux Capacitor within Revit
541 Downloads
Bench Grinder
Bench Grinder
Two Wheel Bench Grinder
2349 Downloads
BOSE Acoustimass - Saltellites (black)
Product Version: Revit Building 8.1
2098 Downloads
BOSE Acoustimass - Saltellites (silver)
1177 Downloads
BOSE Acoustimass - Saltellites (white)
1248 Downloads
BOSE Acoustimass - Subwoofer (black)
1726 Downloads
BOSE Acoustimass - Subwoofer (white)
1138 Downloads
BOSE Lifestyle Center
1836 Downloads
Breaker - Disjoncteur
A differential circuit reaker, for electric boards
Disjoncteur différentiel, adaptable aux tableaux éléctriques
Position : On / Off
523 Downloads
Cable Tray
Cable Tray
Line-Based Parametric Cable tray that I created.  Improve and re-post!  Hopefully it won't break!  (Can't do super small segments, unless you turn down the MAX SUPPORT SPACING param, and then you'll have more supports than you want, probably should add an if/then when segment is too short.)
3 Stars from 4 Votes
Product Version: Revit MEP 2009
8527 Downloads
Capstone C65 Microturbine with ICHP
Cogen with flue gas heat recovery module. Does not include low emmissions package.
Product Version: Revit MEP 2016
272 Downloads
Cast Iron Radiator
Cast Iron Radiator
Radiator.   It's not parametric or anything, but it'll do.
4 Stars from 8 Votes
10776 Downloads
Ceiling-based security camera
5 Stars from 2 Votes
6058 Downloads
Chatsworth 2 Post Rack
Standard silver 2 post rack for communication equipment
2387 Downloads
Chatsworth rack with cable management
7' Black Chatsworth patch panel rack with cable management on each side.
3558 Downloads
Combined Television VHS
TV VCR combination Sony 51 cm
2 Stars from 1 Votes
11301 Downloads
Contactors Enclosed Non Combination
1244 Downloads
Data Cabinet
Data Cabinet
Model of a Wall Mounted Data Cabinet
http://www.rfmote.com/
parametric size c/w 3 sizes setup in the family
3.5 Stars from 4 Votes
3873 Downloads
Page generation time: 0.6433
