45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 5 | 1 | 2 | 3 | 4 | 5 Next >>
10 - Toilet Accessory - Sanitary Napkin Disposal
3.5 Stars from 2 Votes
Product Version: Revit Building 9
20134 Downloads
2D 60 x60 ADA Toilet Stall
Product Version: Unknown
5228 Downloads
3-Roll Toilet Paper Dispenser
Product Version: Revit Building 8.1
9426 Downloads
3D Grab Bar w/ Vertical
Product Version: Revit Building 9.1
1767 Downloads
3D Tub-shower enclosure with opening
I added a parametric window opening to the existing Tub-shower enclosure created by someone else.
The width, height, and location of the opening are parametric.
Product Version: Revit Structure 2009
4867 Downloads
84"- 36" Commercial Bathroom Mirror
A Mirror that is used for smaller coimmercial bathrooms
1 Stars from 6 Votes
17035 Downloads
ADA Corner Grab Rail for Toilet
Stainless Steel Grab Rail
15964 Downloads
ADA Grab Bar
ADA Grab Bar
ADA Grab Bar
3.5 Stars from 4 Votes
26906 Downloads
ADA Handrails
ADA Handrails
ADA Handrails
14510 Downloads
Adult Change Table
Adult Change Table
Adult change table based on Pressalit Care 1000 Adult Change Table. Model number R8402/R8403
2 Stars from 1 Votes
2897 Downloads
Air Hand Dryer
Air Hand Dryer
Air Hand Dryer
1 Stars from 1 Votes
12862 Downloads
Arched Mirror
Arched Mirror
1200mm x 900mm w arched mirror.  Framed in oak (10mm) 900mm offset from base.
2901 Downloads
Armchair
_modern_armchair
1755 Downloads
au.Towell rail - Dbl bracket.rfa
3 Stars from 1 Votes
4824 Downloads
automatic air hand dryer - generic
4 Stars from 3 Votes
5108 Downloads
Automatic Air Hand Dryer - New and Improved!
Air hand dryer 506 - now a wall-hosted model.  Added symbolic lines so the dryer displays properly in floor plan views.
3 Stars from 2 Votes
25598 Downloads
Axor Montreux Soap Dish
4226 Downloads
Baby Changing Station
3.5 Stars from 6 Votes
11822 Downloads
Bath Caddy w/ wine glasses
Orsen tub tray with two empty wine glasses
798 Downloads
Bathroom mirror
Bathroom mirror
A Bathroom mirror that is also a medicine cabeinet.  Has an excellent rendering appearance and has adjustable lengths
3 Stars from 9 Votes
83717 Downloads
Bathroom stall
Bathroom stall
Bathroom stall, can be specified as either regular or handicap, height fully adjustable, can also specify handicap stall to left or right of regular stall to recongifure, depth adjustable
4.5 Stars from 7 Votes
76110 Downloads
Bathroom Vanity Parametric
5 Stars from 15 Votes
66320 Downloads
Bathroom Vending Dispenser
3938 Downloads
wall mounted
4684 Downloads
4496 Downloads
Bobrick B-3471
Sanitary napkin and toilet paper dispenser two sided thru wall with partition thikness parameter
1903 Downloads
BOBRICK B-43944 SEMI-RECESSED TOWEL DISPENSER & WASTE RECEPTACLE
BOBRICK B-43944 SEMI-RECESSED TOWEL DISPENSER & WASTE RECEPTACLE WITH CORRECT PROPORTIONS & MASK REGION TO COVER WALL PATTERNS IN SPACE BETWEEN UPPER AND LOWER SECTIONS.
4 Stars from 1 Votes
2953 Downloads
Bobrick Grab Bar B6137
BOBRICK Grab Bar # B8137
8006 Downloads
Bobrick Paper Towel Dispenser - B-3944
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-3944 paper towel dispenser.
7293 Downloads
Bobrick Soap Dispenser - B-40
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-40 soap dispenser.
5566 Downloads
Page generation time: 0.6366
