12' Big Ass Fan. Don't know parameters well enough to make this fan be variable so if someone is good with doing that be my guest. |
Product Version: Revit Building 9.1
10200 Downloads
Downloaded this fan and made it parametric. Original design by JHanby. |
Product Version: Revit MEP 2018
2664 Downloads
This Indoor unit can be used for the interior purpose only. |
3559 Downloads
BASEBOARD HEATER
High Efficiency Ceramic Infrared Panels
The CeramiCircuit™ Baseboard Heater mounts on a wall near the ground and provides consistent warmth. This heater works well as a replacement for an old convective baseboard heater. With the 527 or 545, you enjoy heat without the hazards generally associated with a non radiant baseboard. No risk of a fire, no forced-air, just reliable heat.
Radiant Electric Heat
Product Website: http://electricheat.com/products/baseboard/
Product Cutsheet: http://electricheat.com//wp-content/uploads/2013/12/Baseboard-Cut-Sheet.pdf
3-Part Specification: http://electricheat.com//wp-content/uploads/2013/12/238330-REH3-part-Specification.pdf
Submittal Sheet: http://electricheat.com//wp-content/uploads/2013/12/REH-Baseboard-Submittal-Sheet-May2012.pdf
Operation Manual Installation Instructions: http://electricheat.com//wp-content/uploads/2013/12/Baseboard-Mounting-Instructions-2011B1.pdf |
2469 Downloads
Szintén buta, mint a tök. Nem sokára indul a weboldal, ahonnan az intelligens verzók letölthetők lesznek.
Ennek ellenére a tetljes mérettáblát képes lekövetni, a beépítési magasság automatikus, de felülbírálható.
oops! Az lemaradt, hogy a "T" nevű paraméterrel lehet vezérelni. Egész szám paraméter, azt kell nyomkodni felfelé, minden szám egy méretet jelöl. A'sszem 12 méret van. |
No rating |
Product Version: Revit MEP 2010
987 Downloads
No rating |
Product Version: Revit Structure 2012
618 Downloads
No rating |
533 Downloads
Broan Model HD80L Bathroon Exhaust fan light combo |
No rating |
Product Version: Revit MEP 2009
3525 Downloads
Caseta de cobro automática para comercio. |
12543 Downloads
CEILING HEATER – SURFACE MOUNTED
The CeramiCircuit™ Ceiling Heater fixes on the upper interior surface of a room. The Ceiling Heater’s position allows for a wide and even distribution of heat. In just 5 to 7 minutes, the room’s objects and you are fully bathed in radiant heat, so you can focus on the day ahead in maximum comfort. Our Surface Mounted Heater works great in both commercial and residential settings.
Product Website: http://electricheat.com/products/ceiling-heater-surface-mounted/
Product Cutsheet: http://electricheat.com//wp-content/uploads/2013/12/Ceiling-Surface-Mount-Cut-Sheet.pdf |
1737 Downloads
CERAMICIRCUIT™ HEATERS – LAY-IN
The CeramiCircuit™ Lay-In Ceiling Heater is ideal for institutional and commercial application where acoustical tile ceilings exist. Install a few units to address a cold spot, or use them as the primary heat source in an office.
Product Website: http://electricheat.com/products/ceiling-heater-lay-in/
Product Cutsheet: http://electricheat.com/wp-content/uploads/2015/09/1624CL-Cut-Sheet-9.2015.pdf
3-Part Specification: http://electricheat.com/wp-content/uploads/2015/09/238330-REH3-part-Specification-9.30.2015.pdf
Submittal Sheet: http://electricheat.com/wp-content/uploads/2015/09/Ceiling-Submittal-Sheet-9.2015.pdf
Operation Manual Installation Instructions: http://electricheat.com//wp-content/uploads/2013/12/1624CL-Drop-In-OM-WEB1.pdf |
No rating |
601 Downloads
CERAMICIRCUIT™ COVE HEATER
The CeramiCircuit™ Cove Heater is a great choice to heat virtually any space. Customers have been successful heating areas as diverse as Bikram yoga studios, full houses and drafty sections in restaurants. We offer a variety of Cove Heaters in different sizes and intensities to custom meet your heating needs. Like our Lay-In Ceiling Heater, our Cove Heaters are energy efficient and can reach and maintain a higher temperature quicker than any competing brand.
Product Website: http://electricheat.com/products/coves/
Product Cutsheet: http://electricheat.com//wp-content/uploads/2013/12/Cove-Cut-Sheet.pdf
3-Part Specification: http://electricheat.com//wp-content/uploads/2013/12/coves3-part-Specification-1.pdf
Submittal Sheet: http://electricheat.com//wp-content/uploads/2013/12/Cove-Submittal-2011.pdf
Operation Manual Installation Instructions: http://electricheat.com//wp-content/uploads/2013/12/Cove-Installation.pdf |
No rating |
694 Downloads
Difusor redondo MEP |
No rating |
245 Downloads
Parametric grate for MEP uses |
No rating |
1352 Downloads
Rejilla de inyeccion (MEP) |
No rating |
328 Downloads
No rating |
206 Downloads
Parametric round ceiling diffuser for MEP uses |
2632 Downloads
Modeled from Daikin air conditioning inverter dimensions & appearance. May be of use in showing air con plant in residential or light commercial applications. |
Product Version: Unknown
16094 Downloads
A wall mounted extract fan for wetrooms, ultility and kitchens.
Based on a Vent Axia Lo-Carbon Centra dMEV Unit |
No rating |
2491 Downloads
Material Parameter
6" x 10" or 4" x 10"
Please Rate |
1857 Downloads
parametric door lock
door panel size parametric |
No rating |
4758 Downloads
Porta in vetro |
No rating |
1038 Downloads
Double-Sided-Fireplace |
18184 Downloads
Product Version: Revit Systems 2
2866 Downloads
AVAILABLE IN ANY COLOR! ADJUSTABLE MOUNTING STEM. |
1889 Downloads
IT JUST CREATED AS AN GENERIC MODEL AND CONNECTION ONLY GIVEN AS PARAMETRY .
MATERIALS ARE APPLIED AS PER SERVICE REQUIREMENTS. |
1631 Downloads
Manufactured by: Flos
This revit model has been created using available DWG format information. |
No rating |
299 Downloads
Hutch with three cranes |
432 Downloads
Line base Drain Channal |
Product Version: Revit MEP 2012
5492 Downloads
Recreated from spec of Woodland Direct this is a 75,000 BTU 36" long by 8" wide Linear Gas Insert with associated forms for electronics & valves to illustrate clearances required. Not parametric but easily converted if necessary. Includes Lighting Metric. Thanks to TroySmithFreak for the flames from his full fire pit ... be sure to check that out too. |
4436 Downloads
