89 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 5 | 1 | 2 | 3 | 4 | 5 Next >>
10 - Perforated Return Grille
The 10 Series Perforated Return Grille is designed to match perforated supply diffusers to provide a coordinated aesthetic throughout a space. Featuring 51% free area, the 10 Series grille maintains low noise and pressure drop in high capacity return applications.
Product Version: Revit MEP 2020
338 Downloads
11 metre transport truck
This is an eleven metre delivery truck based on the other truck found on this website.
Product Version: Unknown
11163 Downloads
1 Stars from 1 Votes
6652 Downloads
12x12 Supply Diffuser w/ auto-size connector
Uses IF statements to automatically size duct connector based on CFM. Fully adjustable CFM ranges for 4" to 8" sizes. Use one family with one type, no need to change to a new type with a different connector size when you change CFM. Non-hosted family.
2 Stars from 1 Votes
Product Version: Revit MEP 2012
3821 Downloads
150 - Heavy Duty Louvered Supply Grille
Ideal for industrial applications, the 150 Heavy Duty Louvered Supply Grille features individually adjustable blades spaced on 1.5 in. centers to accommodate large air volumes and provide directional control suitable for spot heating and cooling.
381 Downloads
23/30 - Airfoil Supply Grille
Price Industries Airfoil Suply Grille
The 20/30 Series Airfoil Supply Grille features premium quality, extruded aluminum construction. Individual blades are fully adjustable and the airfoil shape helps to reduce turbulence, leading to low sound and pressure drops.
122 Downloads
24x24 Supply Diffuser w/ auto-size connector
Uses IF statements to automatically size duct connector based on CFM. Fully adjustable CFM ranges for 6" to 15" sizes. Use one family with one type, no need to change to a new type with a different connector size when you change CFM. Non-hosted family.
1 Stars from 2 Votes
4291 Downloads
4-6"Ø Engine Exhaust Duct Silencer
1816 Downloads
500FF/600FF - Filter Frame Louvered Return Grille
Price Industries Louvered Filter Frame Grille
The filter frame is intended to be incorporated into a conveniently serviceable return air filtration system and is designed for recirculating air systems
102 Downloads
6.6M High Galvanize Water Tank Frame
6.6m kamals high galvanize water tank frame for 2floor structure.
1745 Downloads
60/70 - Airfoil Return Grille
The 60/70 Series Airfoil Return Grille features premium quality, extruded aluminum construction, resulting in clean, crisp detailing to blend with almost any architectural surrounding. The heavy extruded aluminum blades are fixed at a 45° angle for minimal see-through.
154 Downloads
700 - Stainless Steel Louvered Grille
Price Industries Stainless Steel Louvered Grille
The 700 Series Louvered Grille makes uses adjustable (supply) or fixed (return) blades to control airflow and provide a supply or return unit with minimal see-through.
251 Downloads
90 - Heavy Duty Return Gym Grille
The 90 Series Heavy Duty Return Gym Grille features a fully welded border and mandrel tubes that support the blades to prevent damage, making them ideal for heavy duty applications. Available in both steel and aluminum construction with multiple core styles and mounting options, the 90 Series can be customized to suit each application.
71 Downloads
AC Thru wall Unit
AC Thru wall Unit
AC Thru wall Unit
4 Stars from 11 Votes
13564 Downloads
AIR GRILL
AIR GRILL
103 Downloads
Air-Conditioning Vent - Stivi
General 4-way AC distribution vent.
10519 Downloads
Airport Baggage Claim Conveyor
4.5 Stars from 2 Votes
7953 Downloads
Aldes Ceiling Register Box
Aldes CERB Exhaust & CSRB Supply standard and high pressure option. Separate grille included. Created types for most CFM ranges available up to 8" CAR.
Product Version: Revit MEP 2017
768 Downloads
Aldes CR3 CAR Wall Register
Aldes Wall Register with constant airflow regulartor. 4-10"Ø sizes, regular and with Fire Damper.
39 Downloads
Aldes Parallel Zone Inline Register Terminal PDIL
Aldes PDIL Paralel Zone Damper Terminal with Airflow Regulator.
Product Version: Revit MEP 2019
122 Downloads
Aldes Single Zone Inline Register Terminal SDIL
Aldes SDIL Single Zone Damper Terminal with Airflow Regulator.
56 Downloads
Aldes Zone Inline Register Terminal IL-2 With Bottom Access
Aldes IL Zone Damper Terminal with Airflow Regulator with Bottom Access. Allows control of min & max flow rates.
181 Downloads
AMCD - Adjustable Modular Core Directional Diffuser
Price  Industries Adjustable Modular Core Directional Diffuser
The modular core directional diffuser (AMCD) supplies large volumes of air at low sound levels and pressure drops. The modular core design allows for easy, tool-free reconfiguration of the discharge pattern and easy access to ductwork for maintenance. With a tight horizontal discharge air pattern, even at low air volumes, the modular core directional diffuser is well suited to VAV applications.
72 Downloads
Armstrong Vortex Air Separator
Available Sizes: 4", 5", 6", 8", 10", & 12"
Use the In;et_Outlet Diameter to change size.
Product Version: Revit MEP 2015
703 Downloads
ATG - Aluminum Transfer Grille
Price Industries Aluminum Transfer Grille
Transfer Grilles offer the largest free area possible with the option of a sight-proof or light-proof core. Transfer grilles are designed for use in doors and partitions to allow for smooth transfer of air between spaces. Such spaces include storage rooms and restrooms.
76 Downloads
Avco - SS Ball Valve - 1100 Series Flg x Flg
Available Sizes:
1/4" | 1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 2" | 2 1/2" | 3" | 4"
633 Downloads
Avco - SS Ball Valve BW x BW - ETO 2100 Series
Available Sizes:
1/2" | 3/4" | 1" | 1 1/2" | 2" | 3" | 4"
1139 Downloads
Avco - SS Ball Valve Flg x Flg - Class 150 9100 Series
Available Sizes:
1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 2" | 2 1/2" | 3" | 4" | 6" | 8" | 10" | 12"
*Note: Do not use This Family for 1.25" - Use Series 1100
854 Downloads
Avco - SS Ball Valve NPT x NPT - 1100 Series
Available Sizes:
480 Downloads
Avco SS 3-Way Ball Valve
Available Sizes:
1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 1 3/4" | 2"
667 Downloads
Page generation time: 0.6303
