More detailed car than 1996 Cadillac |
No rating |
Product Version: Revit Structure 2018
1705 Downloads
842 Downloads
Japanese made Toyota HiAce. mid LOD. Improved Level of Detail. Included Inventor and Revit versions |
No rating |
1555 Downloads
72"x28.5" Three door fridge for use in a restaurant, and has top for work space. |
No rating |
5194 Downloads
Bard Wall Hung Unit, modeled with high detail. Does add a bit of MB's to your file. (Extremely Non-Parametric, sorry!) |
2368 Downloads
Price Industries Heavy Duty Airfoil Grille
The 300 Heavy Duty Airfoil Supply Grille is well-suited to industrial applications, with individually adjustable blades and wide blade spacing for maximum free area and the ability to spot heat and cool. |
No rating |
Product Version: Revit MEP 2020
315 Downloads
This is a Dimension sst 1200es 3D printer that I modeled for a project.
Solid, not hollowed. If you want to make a better screen than I did you are more than welcome to, shouldn't be too difficult. The screen is a material, not a decal, because I have a long series of issues with trying to make decals work. |
10469 Downloads
No rating |
4874 Downloads
Parametric Return Price Industries 80-Egg Crate |
No rating |
268 Downloads
No rating |
Product Version: Revit MEP 2009
1598 Downloads
No rating |
Product Version: Revit MEP 2010
831 Downloads
Adaptive moving walk.
How to use:
load to proyect, hit load on workplane, pick or select workplane, click start point, click endpoint.
Go to elevation, and set the levels it will conecct.
Its not fully parametrized in the some dimensions, only lenght, width and height, and its geometry is simplified to have a bunch of these on your proyects.
Feel free to rate and modify |
16032 Downloads
AHU-1200 CFM |
No rating |
Product Version: Revit MEP 2013
2070 Downloads
6200 Downloads
Air Conditioning Unit - Thru Wall |
Product Version: Unknown
15489 Downloads
No rating |
1533 Downloads
This is an Air Curtain AKA Fly Fan, generally used by restaurants to control flies at doorways. This is based on a Mars Air Systems CM-36 |
3462 Downloads
6215 Downloads
No rating |
2970 Downloads
Trane Model CGAM040F2**2A Series
Educational Purpouse only |
No rating |
793 Downloads
Air_Receiver 1m3 with connetors 1 1/"
Revit 2019 |
No rating |
457 Downloads
ADJUSTABLE WATER TANK SIZE.
SMALLEST 1M X 1M X 1M |
No rating |
1276 Downloads
I redesigned an anemometer that is installed on an existing photovoltaic system
Made with REVIT Architecture 2023 |
128 Downloads
Parametric Cooler Tower by EVAPCO, This contains Models 9-3G8 through 9-7J8
This was modeled in Revit using manufactures cut sheets. |
Product Version: Revit MEP 2012
5310 Downloads
Automatic fire extinguisher 11 kg to 44 KG |
Product Version: Revit MEP 2015
1378 Downloads
1762 Downloads
No rating |
1140 Downloads
No rating |
Product Version: Revit Structure 2019
380 Downloads
This is my 1st attempt at a family. I could not get the electrical connection to move to the right place. I have the supply and exhaust correctly placed. |
No rating |
4196 Downloads
I made some changes, Has correct Loads and air is blowing right Direction. |
No rating |
535 Downloads
