11 7/8 inch I-Joist Arrows |
Product Version: Unknown
2897 Downloads
14 inch I-Joist Arrows |
No rating |
1564 Downloads
This is a 2-pick line-based break line symbol. After you click once to start the break line, an invisible line arrow will appear to indicate which side of the line the mask will be on. By default it masks on the same side/direction as the exterior side of walls, i.e. outer side of a clockwise loop.
It also has a view scale parameter, which you can enter before you start drawing the break line. Simply enter the view scale for each break line you draw, and all your break line jogs in your entire project will match size and shape exactly.
Note: the arrow is only visible while drawing the break line, or when you hover the mouse over it or pick it. |
14371 Downloads
This component is used to put 2d lines in a model for closet rod and Hangers It is parametric in length and easy to pull the ends to the length of the closet. |
19547 Downloads
2X10 floor joist arrows |
No rating |
2184 Downloads
2x12 Floor Joist Arrows |
No rating |
2045 Downloads
2X8 floor joist arrows |
No rating |
1649 Downloads
9 1/2 inch I-Joist arrows |
No rating |
1297 Downloads
Align symbol made in Revit 2012 using instance parameters to adjust the depth and width of the symbol. Arrowheads are 1/8" 30degree filled arrowheads. |
No rating |
1371 Downloads
Plan or detail break line symbols. |
No rating |
391 Downloads
Generic Annotation - FOR REFERENCE ONLY stamp |
No rating |
Product Version: Revit Building 9.1
1237 Downloads
Simple parametric arrow |
No rating |
11152 Downloads
Arrow - Detail Component with solid fill and instance parameters - Fully customizable |
No rating |
2592 Downloads
This annotative familiy has adj. arrow head and adj text |
No rating |
Product Version: Revit Structure 2012
1840 Downloads
Another Arrow. Sorry but in r2014 format |
15787 Downloads
These Revit Schedules are a room schedule filtered for the room named Attic and a soffit schedule that includes a soffit pretending to be the ridge vent. The soffits model across the whole roof including the eaves to get the required area. The ridge vent is a narrow soffit at the ridge the length of the ridge minus the width of the boundary. I have included the stand alone schedules with no model at www.revitcity.com . The math formulas are in the schedules and can be modified per required code. The formula for the ridge vent is the perimeter of the ridge / 2. The ridge boundary is as narrow as possible so I can get a length value. Conditional values are set to black out the values if the manufacture is not who I need it to be. I think it’s pretty cool. If you have any questions feel free to email me at JustinDesigns3D@gmail.com. Enjoy :-) |
No rating |
1268 Downloads
Battery Panel |
1209 Downloads
2D Communications |
No rating |
1695 Downloads
Here's a switchboard for addressing up to 256 devices? I just made it for the challenge--eletrical/data is not my field.
This annotation automatically converts any integer up to 256 into its (up to) 8 digit binary eqivalant, and moves the toggles to the correct locations.
There's some parameter kung-fu in there.
revit 2013. |
437 Downloads
Leader W/o text |
6068 Downloads
Braced Panel Symbol |
No rating |
1017 Downloads
No rating |
Product Version: Revit Structure 2009
628 Downloads
Break Line |
No rating |
Product Version: Revit Building 5.1
9215 Downloads
This cylinder break line will align with the center of the column, has grips for the masking region and a parameter for the column diameter. |
No rating |
900 Downloads
Camera icon with parametric arrow and text to mark the position, direction and name of the camera that REVIT use to built the 3D view |
4564 Downloads
Carbon Monoxide Detector |
No rating |
3215 Downloads
Cartographics Symbols from HOK extracted from AB4564-HOK PresentationThatPop resource file
No rating |
2268 Downloads
Based on post from
https://forums.autodesk.com/t5/revit-architecture-forum/chimney-symbol/td-p/10530717 |
No rating |
349 Downloads
Contact RH |
No rating |
583 Downloads
Control Panel |
No rating |
1223 Downloads
