First, thanks to revity city user @clars for uploading this and I used it to modify to armless model in David Edwards 'Lolita' collection. Dimensions pretty much match with original but not parametric. The model has two fabric texture. Modify as needed !!! |
21336 Downloads
1 Seat Sofa |
Product Version: Unknown
39945 Downloads
Made from 20 mm extrusion with model lines for legs and backrest. Simple chair perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. |
2608 Downloads
True 2D Metric Mass chair made from flat surfaces and lines. Simple chair perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. |
11199 Downloads
True 2D Metric Mass stool made from flat surfaces and lines. Simple stppö perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. |
No rating |
1358 Downloads
Simple armchair made from an extrusion and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. The beam is offset to counter line clipping through the table top surface. |
No rating |
1937 Downloads
Toulon Side Chair with chromed steel frame and leather upholstery. 19.5"W x 22 1/4" D x 32 1/4" H Can be found at 2bmod.com |
14464 Downloads
3' wide, modern 3d chair, simple
looks good in plan, elevation, 3d |
2951 Downloads
No rating |
5559 Downloads
Acapulco Chair - nom parametric |
No rating |
4912 Downloads
Version: Rac2015
Please rate.
Thanks |
7678 Downloads
Adirondack chair based on Popular Mechanics.com/outdoorfurniture instructions |
25690 Downloads
This is my first chair. I hope whom ever downloads it will like it. The Adirondack Chair is a bit larger then the average. |
18478 Downloads
Product Version: Revit Structure 2009
31731 Downloads
Adirondack chair and matching table based of my own. Enjoy!
Revit 2014 |
16315 Downloads
This Adirondak chair has some flexible parameters, but not really necessary. It was my first family creation. |
No rating |
1059 Downloads
An Adirondak chair project I modeled for the hell of it. Comes with a sheet with dimensions and a bill of material if you want to make one. |
No rating |
3495 Downloads
Adjustable Theatre Seats |
35951 Downloads
Aeron Work Chair |
Product Version: Revit Building 9.1
50398 Downloads
Materials can be changed. |
19603 Downloads
18370 Downloads
Anova Airi Stix 6' Contour Bench |
No rating |
Product Version: Revit Architecture 2019
4378 Downloads
Anova Airi Stix Outdoor Chair |
No rating |
2713 Downloads
red and white sphere chair |
18001 Downloads
5327 Downloads
http://www.allermuir.com/Products.aspx?RangeId=106
For more great, high quality Revit components go HERE! |
19039 Downloads
http://www.allsteeloffice.com/acuity/
modeled in Revit, not just a 3D cad file
material parameters as offered by allsteel
29739 Downloads
fabric sofa |
50803 Downloads
14142 Downloads
Design by Hans Streitner Architekten, HSA 1985 |
No rating |
947 Downloads
