Modeled after the Samsung LN40D630M3FXZA, materials parametric. Not wall-based. Revit 2012 |
Product Version: Unknown
27834 Downloads
Parametric detailed model of ultra-thin 2016 LG Models 55 & 65BGP OLED TVs on black and clear plastic base. Base grouped and can be deleted for wall hung use. |
Product Version: Revit Structure 2016
21735 Downloads
No rating |
9568 Downloads
StandAlone AGRV_SANR-FIXT_Dryer_乾衣機
Metric Dryer with DIM & Material parameters and dimension Guide (Model text can be trun on or off)
Visit our website AgileRevit.com for more families |
No rating |
572 Downloads
AGRV_SANR-FIXT_GasMeter_瓦斯錶
Metric GasMeter with DIM & Material parameters and dimension Guide (Model text can be trun on or off)
No rating |
71 Downloads
AGRV_SANR-FIXT_GasWaterHeater_瓦斯熱水器
Metric GasWaterHeater with DIM & Material parameters and dimension Guide (Model text can be trun on or off)
No rating |
70 Downloads
AGRV_SANR-FIXT_InstantaneousElectricWaterHeater_即熱式電熱水器
Metric InstantaneousElectricWaterHeater with DIM & Material parameters and dimension Guide (Model text can be trun on or off)
No rating |
59 Downloads
AGRV_SANR-FIXT_ThermalStorageElectricWaterHeaterA_儲熱式電熱水器A
Metric ThermalStorageElectricWaterHeaterA with DIM & Material parameters and dimension Guide (Model text can be trun on or off)
No rating |
91 Downloads
AGRV_SANR-FIXT_ThermalStorageElectricWaterHeaterB_儲熱式電熱水器B
Metric FIXT_ThermalStorageElectricWaterHeaterB with DIM & Material parameters and dimension Guide (Model text can be trun on or off)
No rating |
63 Downloads
StandAlone AGRV_SANR-FIXT_WasherDryers_洗脫烘洗衣機
No rating |
453 Downloads
StandAlone AGRV_SANR-FIXT_WashingMachineA_洗衣機A
Metric WashingMachine with DIM & Material parameters and dimension Guide (Model text can be trun on or off)
No rating |
290 Downloads
StandAlone AGRV_SANR-FIXT_WashingMachineB_洗衣機B
No rating |
314 Downloads
Materials are listed under the properties tab in the edit type section for an easy change to any material or color that you would like. Not Parametric just the size of a regular Alarm Clock. |
850 Downloads
No rating |
1033 Downloads
This is an arched carport shade I made for a friend by request for his project.
The length of the carport is parametric as are the materials.
I tried to figue out how I could make the tilt angle parametric and the width but it is complicated by the seeming limitations on the sweep curves and how they change as the ange flexes and the back to front length changes. (Suggestions if you have them would be appreciated) |
2636 Downloads
Outdoor Built-in Barbecue
Based on the Napoleon BIPT450 |
15510 Downloads
No rating |
3343 Downloads
Simple iPod Dock based on Bose's model |
No rating |
3528 Downloads
caminetto classico ad angolo non parametrizzato |
No rating |
1647 Downloads
I took the component below and made it parametric...
CSI Division: 23 50 00 Central Heating EquipmentRevitCity Division: Electrical > Equipment
Uploaded By: JLinkUploaded On: Wed, Nov 4, 2009 |
No rating |
5216 Downloads
Ceiling fan manufactured by Masterfan
56 inches
(set to 70 inches custom length)
Satin aluminum finish |
No rating |
Product Version: Revit Structure 2019
2060 Downloads
A central vacuum power unit (canister) based on a BEAM vacuum system. Mounting height is adjustable |
3476 Downloads
NOHS made |
No rating |
1293 Downloads
1861 Downloads
circular coffee table, includes chairs |
4478 Downloads
Dell Television. Now includes an image (football of course) |
105293 Downloads
Speaker that comes with the Denon DM37 DAB Mini Hi Fi |
No rating |
1760 Downloads
Denon DM37 DAB Mini Hi Fi. There's a speaker around here somewhere too |
No rating |
1188 Downloads
No rating |
Product Version: Revit MEP 2009
1396 Downloads
A 400 x 600mm and 220mm deep domestic surface mounted meter kiosk. |
No rating |
2504 Downloads
