53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
01_Mueble de tv
01_Mueble de tv
One of my components completely done for me!!!!
4.5 Stars from 12 Votes
10764 Downloads
24" wide belt conveyor
24" wide belt conveyor.  Can be manually adjusted to make longer or shorter.
3 Stars from 2 Votes
Product Version: Revit MEP 2012
7236 Downloads
35 foot glass elevator
4 Stars from 5 Votes
15292 Downloads
5-Ton Bridge Crane
5-Ton Bridge Crane
Dual driven underhung bridge crane, designed to carry 5 tons. Is ground based, with runway beams adjustable on both sides of bridge.
1 Stars from 1 Votes
3893 Downloads
7 x 16ft enclosed trailer
7 x 16 foot enclosed trailer with side door
Product Version: Unknown
3168 Downloads
Adjustable Under-hung Bridge Crane
Under-hung Bridge Crane with adjustable length and width. Floor based so set offset height.
4 Stars from 1 Votes
6586 Downloads
AGRV_GENM-SPCQ_CargoElevatorS_貨用電梯S
StandAlone CargoElevator S (2Door)
Metric CargoElevator S (2Door) with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families
2906 Downloads
AGRV_GENM-SPCQ_ElevatorDoorA_電梯門A
Wall based ElevatorDoorA
Metric ElevatorDoorA with DIM & Material parameters and dimension Guide
3247 Downloads
AGRV_GENM-SPCQ_ElevatorDoorB_電梯門B
Wall based ElevatorDoorB
Metric ElevatorDoorB with DIM & Material parameters and dimension Guide
12 Downloads
5 Stars from 3 Votes
1200 Downloads
AGRV_GENM-SPCQ_Escalator_電扶梯
Metric Escalator (Generic model) with DIM & Material parameters and dimension Guide, base on mitsubishi escalator.
The angle of the escalator are also drived by parameter.
Visit our website https://www.agilerevit.com/ for more free families
2648 Downloads
AGRV_GENM-SPCQ_MovingWalkwaySlope_傾斜式自動步道
Metric MovingWalkway (Generic model) with DIM & Material parameters and dimension Guide.
1403 Downloads
AGRV_GENM-SPCQ_PassengerElevatorA-2Way_客用電梯A-雙向
StandAlone PassengerElevatorA  (Side Counterweight)(2Way)
Metric PassengerElevatorA with DIM & Material parameters and dimension Guide
233 Downloads
133 Downloads
123 Downloads
3013 Downloads
AGRV_GENM-SPCQ_PassengerElevatorA_客用電梯curse
2118 Downloads
Bellhop Luggage Trolley
NON-parametric Luggage trolley (1200x750mm) used in hotels - brass finished with wheels. (Made from Furniture family)
8040 Downloads
Boom Lift_NiftyTM64 Trailer_SEQ
Parametric Boom Lift.Only shows boom position in the maximum height and horizontal reach position. it was designed for clearence checking.
1462 Downloads
Circular Glass Elevator
Hydralic Glass Elevator. Mechanical Room Basement. Elevator is at base level. Open for family/component editing. Use of another creators lighting (see stair light). Currently set for 5 levels each 13'-4" and basement 6'-0".
4.5 Stars from 11 Votes
51074 Downloads
conveyor
conveyor
conveyor
4.5 Stars from 6 Votes
8079 Downloads
Edited wall-based lift
4 Stars from 10 Votes
40763 Downloads
Electric Elevator
Electric Elevator
Electric Elevator
3.5 Stars from 24 Votes
Product Version: Revit Building 5.1
169512 Downloads
Elevator 20 floor - Elevador 20 pisos
KONE MonoSpace® 700 20 floor KONE elevator
KONE MonoSpace® 700 Elevador de 20 pisos
4 Stars from 11 Votes
2982 Downloads
Elevator updated
Elevator updated
Update to my previuos post
4 Stars from 15 Votes
Product Version: Revit Building 9.1
114186 Downloads
Escalator
Escalator
generic escalator
4 Stars from 4 Votes
20353 Downloads
Escalator
Escalator
Escalator
3.5 Stars from 3 Votes
8392 Downloads
Escalator Kone ECO 35 deg
Hello, i can´t find 35 degrees escalator. I little change the best escalator, whitch i find. It is escalator KONE ECO 3000 Escalator on RevitCity. Thank you for this revit familly. It is good job.
It is in REVIT 2016.
12019 Downloads
Freight Elevator
Freight Elevator
Freight Elevator
38394 Downloads
Handicapped Lift for Enclosure
This is a handicapped lift based on Garaventa Genesis system. Intended to be placed in an enclosure as specified on www.garaventa.ca
3 Stars from 1 Votes
5970 Downloads
Page generation time: 0.6973
