Nana Wall WA67 Folding Walls. Default types have been created for both interior and exterior door systems ranging from 2-12 panels. Single panel systems must be created independently since this family relies on a system of arrays. User may create duplicate types and customize door panel configurations using the nested detail component. All configurations listed on Nana Wall's website for the WA67 series have been provided. Elevation hinge lines should be drafted manually in elevation as required. |
21635 Downloads
A revised version of another on this site that had issues when the model was "flexed". Those problems should be fixed in this. |
Product Version: Unknown
4416 Downloads
16' Overhead Panel Garage Door Colonial |
24935 Downloads
I updated this to allow for different thicknesses of walls. It will create a 4" interior portion of wall and you can have a 4" (or any size larger) exterior portion of the wall. It's loosely based off Weiland exterior sliding pocket doors. This newer version keeps the model objects visible and does not have symbolic/model lines for plan view. |
19338 Downloads
This is a parametric Sliding bi-pass door done in Revit 2017 |
39091 Downloads
415 Series Aluminium Louvres |
Product Version: Revit Building 9.1
10501 Downloads
No rating |
6417 Downloads
parametric 6 panel multi door with glass ( nana wall ) |
No rating |
13786 Downloads
i m doing first time i welcome suggestion |
No rating |
4030 Downloads
The ceiling vent is 8 inches wide and length is parametric. Size of trim and bracing, and materials are also parametric. |
No rating |
9957 Downloads
No rating |
4226 Downloads
8' Overhead Panel Garage Door Colonial |
16862 Downloads
Access Door |
8587 Downloads
According Door |
4672 Downloads
AGRV_Door_HiddenEscape_隱藏式逃生門
with parameters for open/close door in 3D view
Metric Hidden Escape door with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families |
No rating |
440 Downloads
AGRV_Door_OverheadRollingPlusA_含小門捲簾門A
Metric Overhead Rolling door + escape door with DIM & Material parameters and dimension Guide
No rating |
825 Downloads
AGRV_Door_OverheadRolling_捲簾門
Metric Overhead Rolling door with DIM & Material parameters and dimension Guide
No rating |
1917 Downloads
Open at any angler |
No rating |
2803 Downloads
Arch Head Louver with Brick Arch Trim |
10416 Downloads
Arched Door |
No rating |
11217 Downloads
This replaces the original 3701 file, which had a problem with the frame depth in Section |
No rating |
4858 Downloads
Bank Vault door |
10397 Downloads
Residential barn door, single panel with dynamic parameters including open position. Taken from "Sliding_Barn_Style_Double_Door_14548.rfa" off this site and modified for use. |
No rating |
994 Downloads
panel - no trim |
Product Version: Revit Building 5.1
18350 Downloads
Bifold four panel door, 2 panel with arch top |
Product Version: Revit Building 8
8072 Downloads
Simple adjustable Bilco basement bulkhead |
No rating |
1880 Downloads
Pre-Cast concrete basement access stairs similar to Bilco |
No rating |
8115 Downloads
1422 Downloads
This is a security checkpoint stop at entrance gate |
No rating |
286 Downloads
This is a remake and better version of the other upload of the mexican iron arch way |
3053 Downloads
