2984 Downloads
THIS IS TO BE THE 1322 JELD-WEN DOUBLE DOOR WITH 2 12" SIDELIGHTS. I TRIED TO MAKE IT USER FRIENDLY. BUT SINCE I AM STILL LEARNING, I CAN NOT SAY IF IT IS OR NOT. |
Product Version: Revit Building 9
4651 Downloads
16' Overhead Garage Door - Prairie Design |
Product Version: Revit Building 8.1
17816 Downloads
16' Overhead Garage Door - Stockton Design |
19887 Downloads
16' Overhead Garage Door - Wagon Wheel Design |
10687 Downloads
16' Overhead Garage Door - Waterton 1 Design |
10997 Downloads
16' Overhead Garage Door - Waterton 2 Design |
5978 Downloads
8779 Downloads
A 180 Degree Double Swing door - Parametric |
12713 Downloads
Non parametric |
Product Version: Unknown
11734 Downloads
Non parametric |
11717 Downloads
Parametric 2 Panel Slide Door with a Flexble Opening Distance Door Panel and a fixed Panel |
No rating |
Product Version: Revit Structure 2020
823 Downloads
No rating |
366 Downloads
No rating |
336 Downloads
3 Panel Sliding Door |
11753 Downloads
No rating |
3524 Downloads
Full funcitonal parametric overhead door with windows.
You can change everything about this door!
Good luck! |
5495 Downloads
The basic Revit single panel door adjusted so door swing is 45 Degrees in plan. Less clutter. |
5592 Downloads
8 Pane Bifold doors, ideal for opening onto outdoor area |
23460 Downloads
900MM |
4982 Downloads
A Minha Porta |
7862 Downloads
AGRV_Door_2WaySwingDouble_雙向雙平開門
Metric 2Way Double Swing door with DIM & Material parameters and dimension Guide |
No rating |
1036 Downloads
AGRV_Door_2WaySwingSingle_雙向單平開門
Metric 2Way Single Swing door (uneven) with DIM & Material parameters and dimension Guide |
No rating |
649 Downloads
AGRV_Door_BypassSlidingDouble_雙推拉門
Metric Double Bypass Sliding door with DIM & Material parameters and dimension Guide |
No rating |
1108 Downloads
AGRV_Door_FoldingDouble_雙摺疊門
with parameters for open/close door in 3D view
Metric Single Double Folding door with DIM & Material parameters and dimension Guide |
No rating |
1905 Downloads
AGRV_Door_FoldingTriple_三摺疊門
Metric Triple Folding door with DIM & Material parameters and dimension Guide |
No rating |
1132 Downloads
AGRV_Door_FoldingX_多門摺疊門
Metric X piece Folding door with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families |
No rating |
1406 Downloads
AGRV_Door_HungSlidingSingle_單橫拉門
Metric Hung Sliding door with DIM & Material parameters and dimension Guide |
No rating |
1449 Downloads
AGRV_Door_PocketSlidingSingle_單口袋門
Metric Pocket Sliding door with DIM & Material parameters and dimension Guide |
No rating |
900 Downloads
AGRV_Door_SwingDoubleUneven_雙平開子母門
Metric Double Swing door (uneven) with DIM & Material parameters and dimension Guide |
No rating |
782 Downloads
