Fully parametric. Modeled after the Brannen Millwork Euro Frame door, up to the CAD details. Wouldn't go thinner than 6" walls for the frame's sake. |
29279 Downloads
2-Panel- Patio Door |
Product Version: Unknown
26722 Downloads
3 Panel Glass Slider w Trim |
15808 Downloads
3 pieces of window above sliding doors |
2998 Downloads
3-Panel_patio door |
10991 Downloads
18128 Downloads
20616 Downloads
Generic and parametric double sliding door with four panels (two fixed panels and two sliding panels)
Parameters for galzing width, frame width and depth, frame material and glazing material.
2D representation ready but not detailed. |
40749 Downloads
9953 Downloads
AGRV_Door_GlassFoldingDouble_雙玻璃摺疊門
with parameters for open/close door in 3D view
Metric double Glass Folding door with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families |
No rating |
2741 Downloads
AGRV_Door_GlassFoldingTriple_三玻璃摺疊門
Metric Triple Glass Folding door with DIM & Material parameters and dimension Guide
1872 Downloads
AGRV_Door_GlassFoldingX_多門玻璃摺疊門
Metric X piece Glass Folding door with DIM & Material parameters and dimension Guide
No rating |
2208 Downloads
AGRV_Door_GlassSlidingDouble_雙落地窗門
Metric Double Bypass Sliding door (Glass) with DIM & Material parameters and dimension Guide |
No rating |
3203 Downloads
AGRV_Door_GlassSlidingQuadrupleA_四落地窗門A
Metric Glass Quadruple Sliding door (TypeA) with DIM & Material parameters and dimension Guide |
No rating |
1440 Downloads
AGRV_Door_GlassSlidingQuadruple_四落地窗門
Metric Glass Quadruple Sliding door with DIM & Material parameters and dimension Guide |
No rating |
540 Downloads
AGRV_Door_GlassSlidingTriple_三落地窗門
Metric Glass Triple Sliding door with DIM & Material parameters and dimension Guide |
No rating |
1132 Downloads
No rating |
639 Downloads
AGRV_Door_GlassSlidingTriple_三落地窗門A
Metric Glass Triple Sliding door (TypeA) with DIM & Material parameters and dimension Guide |
No rating |
719 Downloads
AGRV_Door_GlassSlidingX_多門落地窗門
Metric Glass X Piece Sliding door with DIM & Material parameters and dimension Guide |
No rating |
494 Downloads
Typical ER/Commercial slingin electric eye entrance door. Parametric overall width and door panel size. |
11430 Downloads
Andersen FWH |
7125 Downloads
Andersen FWO |
5262 Downloads
Andersen FWO4168_41611 10-lite |
3966 Downloads
Andersen FWO5068_60611 15-lite |
4847 Downloads
Sliding glass door based on Andersen 200 series narrow line gliding panel. Includes threshold |
No rating |
1604 Downloads
Lean-To Greenhouse Acces Door (Angled) Full Parametric By Juul |
5890 Downloads
large arched door for commercial building |
17367 Downloads
Made some quick modifications go here for updated door. |
6834 Downloads
Fully parametric arched door with diamond window pattern. For parameters other than Width, Height and Thickness scroll down. I moved them for ease of changing the critical parameters. Adjustable Swing is an instance parameter. There is also a visibility toggle to turn off the line to making it look like a Dutch door.
Fore non arched door go here
Hope it helps,
smh |
No rating |
3572 Downloads
Wooden arched french styled external glass door |
Product Version: Revit Building 9
12444 Downloads
