38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
Baldwin® Estate Metropolitan
Product: Baldwin
Series: Estate
Model: Metropolitan
Handle: Lever
Finish: Stainless Steel Polished
Modeled using RAC 2009.
******Comments and suggestions are welcome
Thanks
3122 Downloads
Baldwin® Estate New York
Product: Baldwin
Series: Estate
Model: New York
Handle: Knob
Finish: Chrome Satin/Stainless Steel Satin
Thanks
3414 Downloads
Product: Baldwin
Series: Estate
Model: New York
Handle: Lever
Thanks
2145 Downloads
Baldwin_Estate_New_York_JA redesign_Door Handle
Original Source :
Product: Baldwin
Series: Estate
Model: New York
Handle: Knob
Thanks
2138 Downloads
Brass Door Handle & Latch
Lockset & Latch, Gloss Brass Handle  Place component in floor plan with an offet of 3'3"
4111 Downloads
Gloss Brass Handle, Lockset & Latch.  Place component in floor plan with an offet of 3'3"
2344 Downloads
Curtain Wall glass door with stainless steel patchlock with thumbturn internally
This lock as an external key access with internal thumbturn, clamped to glass doors.
5 Stars from 3 Votes
Product Version: Revit Building 9.1
6545 Downloads
Custom Door Handle
Custom Door Handle
Custom Door Handle or Latch, residential or hospitality.  For both Single and Double Doors.
4.5 Stars from 7 Votes
Product Version: Unknown
13348 Downloads
Door Knob
Door Knob
Orbit Type Door knob
9948 Downloads
Door Latch
Door Latch
Based on a YALE Single Cylinder Nightlatch.
Finish easy to change - comes as Hammertone Green
4 Stars from 1 Votes
1178 Downloads
Door pull-vert-flat
Door pull-vert-flat
Parametric material and length.  Commericial metal door pull with eased edge perpindicular handle profile
REVIT 2017
5222 Downloads
door rac 2009
first time
742 Downloads
Door Stop
Door Stop
Generic floor mounted door stop
2632 Downloads
Doorknob or Door handle
Basic Doorknob or Basic Handle: Drag into side view and pull out from point of insertion. Go to front veiw to place and floor plan ref level to align with door.
3.5 Stars from 3 Votes
1771 Downloads
Garage Door 12x14 with windows
Made for an RV pull through from a garage door I got here at Revit City.  It's 12' wide by 14' high based on a Clopay design.
16331 Downloads
Garage Door 9'x7' with windows
A 9'wide, 7' high garage door based on the Clopay Classic line. Highly editable so have some fun with it!
12857 Downloads
Gate Bolt Latch
Gate Bolt Latch
This is a Face based Generic Model.
1463 Downloads
Generic Electromagnetic Door Holder
Generic electromagnetic door holder, wall based.
400 Downloads
Interior Left Door Handle
Brass door handle for French doors or single right swing door
Product Version: Revit Structure 2017
5368 Downloads
Interior Right Door Handle & Latch
Brass door handle for French doors or single left swing door with lock
5128 Downloads
Metallic Handle
Metallic Handle
Face Based model with adjustable width and material
68 Downloads
Moddica hinge
Moddica hinge
Moddica hinge MH03 Left Hand
3641 Downloads
Puerta plegable doble hoja paramétrica. Revit 2015
Puerta plegable de dos hojas con parámetros para definir dimensiones, materiales y apertura.
5 Stars from 2 Votes
5077 Downloads
Puerta plegable una hoja paramétrica. Revit 2015
Puerta plegable de una hoja con parámetros para definir dimensiones, materiales y apertura.
4 Stars from 13 Votes
9983 Downloads
stay lift (spring loaded hinge mechanism)
cabinet hinge that swings the door up and a bit off the cabinet
non-parametric
ציר קלאפה טעון קפיץ
731 Downloads
SUPA DOORS - Glass Doors - 5 Panel Design
Download: http://bimobject.com/en/supa-doors/product/glass_doors_5-panel
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-app
All doors are solid stile and rail construction that are all Built To Order, allowing for customization on the fly and are available in any standard heights up to 8’0” tall and 3’6” wide (larger doors available upon request). Stile and rail dimensions may be adjusted without affecting the pricing, including multiple sticking profiles and panel options. Door Thicknesses include 1-3/8", 1-3/4" and 2-1/4". ALL Panel doors may be fire rated in 20 minutes, 45 minutes, 60 minutes, and 90 minutes with concealed closer options. SUPA Doors proudly carry a limited Lifetime Warranty and are STC sound rated to minimize noise (STC 32-45). Doors can qualify toward multiple LEED credits and are manufactured in the USA. Clear, Frosted, and Specialty Glass may be substituted for all panels, and all doors can include prehung wood jambs if desired. Matching stain grade veneer doors available in addition to the standard MDF doors. Please see catalogue for details.
12979 Downloads
Terrassedør
Terrassedør
Terrassedør
1304 Downloads
Tower Bolt_Wall Based (parametric)
This is a simple tower bolt set as a generic wall base model with adjustable height and width
75 Downloads
Trilogy Lockset
Trilogy Lockset
Trilogy combination lockset.
621 Downloads
Window/ Door Louvered Shutters
This family is parametric so you can set the width, height, panel opening angle and louvered blade angles.
It is restricted to 4 panels, 2left and 2 right, and if you open the panels wider than 90degrees it gets confused, so if anyone can fix this for me I will be grateful.
My first upload to RevitCity!
6645 Downloads
Page 1 of 1 |
Page generation time: 0.7264
