111 Users Online (108 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
Adaptive Triangular curtain panel
2041 Downloads
Batt Insulation
Batt Insulation
Detail component Batt Insulation
Batt Insulation with switch to allow for tapered ends for use near eaves or in over the purlin installation in pre-engineered metal buildings.
4.5 Stars from 6 Votes
8776 Downloads
Batt Insulation - Parametric Width & Exact Length
Parameter to change insulation to any width.  Automatically adjusts to any length, unlike the out of the box insulation command.
2194 Downloads
Brush Weatherstrip-Section.rfa
616 Downloads
Built Up Roof with 3" Rigid Insulation
Lined based detail component to be used in roof details
Layers - 1/4" thick mineral cap sheet, 3/4" thick built up roof, 3" thick rigid insulation.
Product Version: Unknown
3197 Downloads
Caulking-Section.rfa
625 Downloads
EIFS
EIFS
EIFS System in Line detail component with leading edge on outside
1633 Downloads
EIFS Detail Comoponent
Simple EIFS Detail Component with adjustable thickness
Spec Section 07 24 00
1490 Downloads
Insulation Batts - keynotable
This is a workaround for the superfluous insulation batt in Revit as you cannot annotate it. This one you can....
3 Stars from 1 Votes
2306 Downloads
Joint in Metal Panel
Product Version: Revit Building 9.1
977 Downloads
Membrane
Membrane
A metric parametric line based family for detailing a membrane / damp proofing / roofing in a section view.
5 Stars from 4 Votes
2726 Downloads
Metal Panel
1310 Downloads
Metal Panel
Various Detail Components for Metal Panel Systems
3159 Downloads
Metal Panel
Metal Panel
1287 Downloads
Metal Panel
Metal Panel
1537 Downloads
Metal Panel
Metal Panel
1585 Downloads
Metal Panel
Metal Panel
1123 Downloads
Metal Panel - Corner Inside
Metal Panel Turns Inside Corner
1036 Downloads
643 Downloads
1170 Downloads
Metal Panel - Outside Corner
Metal Panel turns an outside corner
1383 Downloads
688 Downloads
1058 Downloads
Metal Panel Butts to STF
722 Downloads
Metal Panel Corner
Metal Panel Corner
642 Downloads
Metal Panel Corner Inside
605 Downloads
Metal Panel Joint
Metal Panel Joint
1243 Downloads
Metal Panel on Subgirt
1108 Downloads
1579 Downloads
1204 Downloads
Page generation time: 0.6251
