Panels are designe for a study, library or executive office. Unit comes in white, walnut, and mahogany. Panel shows framed panels, base molding, and crown molding. Sorry I have not figured how to cut them to fit specific walls. However, I created the panels in Autodesk Inventor where you can customized panel above and below windows etc. |
Product Version: Unknown
3792 Downloads
2964 Downloads
No rating |
4781 Downloads
A simple Generic model with options for surface (bark) and end material (tree rings) |
1073 Downloads
Bison brand telescopic paver pedastals for balconies.
Various heights from 1/4" to 12" in one detail component.
Revit version 2012. |
2032 Downloads
BOWMAC Post and Bearer support B197, metric, NZ |
1009 Downloads
No rating |
741 Downloads
No rating |
664 Downloads
4622 Downloads
corniche |
3349 Downloads
961 Downloads
I created this Grommet detail component after one that I found on the Doug Mockett website, series XG1. It's fully parametered (is that a word). |
1196 Downloads
This Detail component is parametric in Width and Depth and the laminations array themselves as well
Enjoy!
This was drawn in Revit 2024 |
No rating |
47 Downloads
No rating |
1048 Downloads
Handrail Section |
No rating |
Product Version: Revit Building 5.1
1900 Downloads
Handrail Section |
No rating |
1717 Downloads
Handrail Section |
No rating |
1731 Downloads
Wood and steel support for linear work counter |
No rating |
1817 Downloads
Lumberlok connections from NZ |
No rating |
201 Downloads
Lumberlok JH47x120 joist hanger, metric, NZ |
No rating |
1686 Downloads
Lumberlok JH47x190 joist hanger, metric, NZ |
No rating |
2640 Downloads
Lumberlok JH47x90 joist hanger, metric, NZ |
No rating |
1459 Downloads
No rating |
Product Version: Revit Building 9.1
973 Downloads
Detail componet with hatch pattern to resemble CAD style. Pattern rotates with object. Linear hatch at 1/4" increments (used two separate hatches offset to bypass revits minimum model hatch scale - pure genius) |
4491 Downloads
Plywood Section detail component made by Dolmit Model Pattern |
No rating |
1713 Downloads
Profile for Porch Rack to be used with 10" Tuscan Column. Use it to build a wall sweep. When moved out from wall, it can be mitered to return against the building. |
No rating |
1030 Downloads
This is a profile for a casing to be used on dormer windows for a typical colonial dormer. |
1669 Downloads
No rating |
1782 Downloads
No rating |
1433 Downloads
Nice profile to create sweep for Band Board. |
No rating |
1109 Downloads
