I'm pretty new on revit families. This is a little profile that you can attach to your wall as reveal to make it look like a corrugated metallic face.
Revit version: 2017 |
No rating |
Product Version: Unknown
3873 Downloads
Product Version: Revit Building 9.1
1129 Downloads
No rating |
2639 Downloads
No rating |
2372 Downloads
No rating |
1572 Downloads
Rejilla tecnica adaptativa |
9165 Downloads
Based on the OOTB AISC Angle Shapes - Side, this family adds a flip operation and the ability to show the leg hidden. |
No rating |
Product Version: Revit Structure 2010
1257 Downloads
3160 Downloads
Product Version: Revit MEP 2009
1307 Downloads
No rating |
2187 Downloads
Anchor Rod with optional leveling nut. Includes embed and project parameters. |
No rating |
Product Version: Revit Structure 2018
4490 Downloads
No rating |
589 Downloads
No rating |
423 Downloads
Australian Purlin Cleat detail |
2930 Downloads
Barandilla de balcón decorativa de hierro fundido |
5732 Downloads
Parametric bent steel plate |
3769 Downloads
Parametric Detail Componenet. An improvement on the OOTB Bolt - Side Family. My biggest beef with this family has always been no washers! Instance parameter adds a washer to the head end or the nut end or both. Instance parameter adds a symbolic bolt hole thru the bolted assembly. Bolt shaft is also a instance parameter. I typically only use A307 3/8"Ø, A325 1/2"Ø, A325 3/4"Ø or A325 1"Ø bolts so these are the only types. Parameters exist though to add more. Type parameters are based on values from Portland Bolt. Revit 2016. |
Product Version: Revit Structure 2016
2383 Downloads
A simple Bolt detail component I created.
xx |
No rating |
2684 Downloads
xx |
No rating |
1302 Downloads
No rating |
865 Downloads
No rating |
664 Downloads
No rating |
617 Downloads
No rating |
502 Downloads
New Zealands gets hammered by the elements, we get rocked by devastating earthquakes. We need to bold stuff down to stop it taking off. Heres a handy steel plate to make it stay where it's meant to be.
You can add a keynote to it to speed up anotations too.
Supplied + used by www.CrawshawArchitecture.co.nz |
1550 Downloads
No rating |
1331 Downloads
No rating |
1796 Downloads
No rating |
1025 Downloads
No rating |
794 Downloads
1180 Downloads
No rating |
1294 Downloads
