familia de bloques de concreto. |
No rating |
1347 Downloads
8" nominal CMU repeating detail |
Product Version: Revit Building 9.1
3294 Downloads
Parametric 3 Core Bull nosed CMU |
2455 Downloads
Parametric split faced CMU |
No rating |
3296 Downloads
CMU - Standard |
Product Version: Unknown
4341 Downloads
Parametric CMU bond beam |
No rating |
4089 Downloads
Parametric split faced CMU bond beam |
2019 Downloads
2485 Downloads
2012 Downloads
This family is to be used in drafting view.
It is a side view of a brick tie, when attaching to a CMU wall.
You can adjust the brick tie to catch the difference between the CMU and brick course if needed. |
2932 Downloads
A bullnose block in section- nominal 8x8. I was searching for this component and couldn't find one, so made one for myself and hopefully it helps someone else. |
No rating |
2769 Downloads
this is the reupload of the Fireplace type 2
Enjoy. |
Product Version: Revit Structure 2013
2430 Downloads
this is a fireplace a half octagon shape chimney
it comes with different styles
Enjoy. |
9674 Downloads
Indoor firelpace.
ps. i forgot to change the family category from door to furniture. feel free to change it your self. sorry
i will reupload it as Fireplace type (reupload) |
No rating |
2616 Downloads
FIREPLACE |
9676 Downloads
can you spot the difference |
No rating |
2027 Downloads
Gold and slate fountain. 40 foot diameter. Because when you're knock, knock, knocking on heaven's door, this is what you'll see. |
No rating |
4162 Downloads
No rating |
738 Downloads
Renders Well |
21033 Downloads
No rating |
3195 Downloads
No rating |
1004 Downloads
Quoins with parametric height and material |
No rating |
2198 Downloads
No rating |
Product Version: Revit Building 6.1
5 Downloads
