Product Version: Unknown
692 Downloads
Albanian Flag with Flag Pole - Editable Flag if you are an Advanced Revit user, the Pole is adjustable and has a host constraint. Enjoy |
2552 Downloads
Baseball field with center field berm |
7104 Downloads
A simple line based detail component to use in batter banks |
No rating |
107 Downloads
linebased and parametric (Slope projection) |
No rating |
890 Downloads
Revit 2009 |
Product Version: Revit Building 9
7505 Downloads
No rating |
840 Downloads
includes options for text, ADA logo, "van" text, and striping. |
16909 Downloads
The AASHTO Greenbook WB-15 semi truck template, turned detail item. Metric units.
This is a detail item which shows turning radii for an AASHTO WB-15 trailer truck. It is used to verify that the design vehicle will turn without bumping into things, or climibng onto curbs.
The radii are parametric, which means you can choose to show all turn angles, just one, or the combination of angles that you want. |
Product Version: Revit Structure 2018
5408 Downloads
Ramp Adjustable Curb Wall, used Railing Profile |
6233 Downloads
Annotate Repeating Detail Component Ramp Slop. |
392 Downloads
208 Downloads
Ramp Adjustable Wall, used Railing Profile |
8828 Downloads
This is road middle line, used railing profile,
Revit 2009 |
15309 Downloads
Revit 2009 |
24423 Downloads
This is road Walkway Edge, used railing profile,
Revit 2009 |
13051 Downloads
A basic, but parametric "house". It is meant to show what an area would look like with other nearby structures.
*Notes*
- Automatic lighting does not work , but it is disabled by default anyway
- Several of the parameters have misleading names
- Feel free to use this however you want
No rating |
369 Downloads
Instance Parameter to turn on or off leaves/canopy. Revit 2017 |
5691 Downloads
www.REVITCARS.com Top View of Mercedes CL-500 (Detail Component family) Add cars to plans, sections and elevations. Enjoy! |
8790 Downloads
Pipe sizes included are 4", 6", 8", 10", 12", 14" and 16". Family is easy to update to add more sizes. |
No rating |
Product Version: Revit Architecture 2019
277 Downloads
SLR344-G80 Weld on Pivoting D link 80. 5 Tonnes.
465 Downloads
