My first car model. might be distored from real life |
No rating |
493 Downloads
4303 Downloads
26766 Downloads
The object is fabricated to support ducts especially when wall mounted bracket is not relevant |
No rating |
Product Version: Unknown
163 Downloads
A double break line that is instance parametric. You can click and drag the control arrows or you can control by instance properties. The zig-zag in the middle will match on both lines.
***This is my first time uploading anything. Please let me know if you encounter any problems or have any suggestions.*** |
No rating |
2682 Downloads
A Detail component. Will not show up in 3D |
Product Version: Revit Structure 2013
3294 Downloads
Detail Component 2d Electric Keyboard Super Hero |
179 Downloads
Built with Revit 2022 |
No rating |
351 Downloads
Line-based detail component with variable symbols/letters spaced evenly along a solid line. I made this family to make up for Revit's lack of symbolic linestyles. Very customizable/parametric.
Good for representing fences, guy wires, overhead power lines, water/gas lines, etc... |
3867 Downloads
Square planter box |
2774 Downloads
Dryer-Ells are ten inch radius, smooth interior elbows that reclaim allowable duct length. Based on ASHRAE methodology for calculating friction loss, they can be measured the same as straight pipe. This removes the run length penalty most code requires for every elbow.
https://dryer-ell.com/introducing-dryer-ell-model-lt45 |
No rating |
343 Downloads
https://dryer-ell.com/introducing-dryer-ell-model-lt90 |
No rating |
541 Downloads
The Dryerbox 350 is the recessed dryer hose protection which allows dryer to be pushed back farther. 2x4 wall, upward ventilation.
https://dryerbox.com/model_DB-350.htm |
No rating |
209 Downloads
The Dryerbox 3D is the recessed dryer hose protection which allows dryer to be pushed back farther. Downward venting, 2x4 wall.
https://dryerbox.com/model_DB-3D.htm |
No rating |
315 Downloads
The Dryerbox 425 is the recessed dryer hose protection which allows dryer to be pushed back farther. 2x6 wall, upward ventilation.
https://dryerbox.com/model_DB-425.htm |
No rating |
249 Downloads
The Dryerbox 480 is the versatile (up or down venting) recessed dryer hose protection which allows dryer to be pushed back farther.
https://dryerbox.com/model_DB-480.htm |
No rating |
169 Downloads
The Dryerbox 4D is the recessed dryer hose protection which allows dryer to be pushed back farther. 2x6 wall, downward ventilation.
https://dryerbox.com/model_DB-4D.htm |
No rating |
252 Downloads
Constructed with all aluminum ribbon, DryerFlex fire-rated duct is as flexible as "slinky" foil flex yet stronger than semi-rigid aluminum.
https://dryerflex.com |
No rating |
669 Downloads
Shorter duct runs, created by venting the dryer straight through the roof, can improve drying efficiency and lessen lint buildup. The new DryerJacks are engineered specifically for dryers. They meet or exceed all code requirements and deliver superior airflow efficiency.
https://dryerjack.com/djk466.html |
No rating |
531 Downloads
https://dryerjack.com/djk486/index.html |
No rating |
410 Downloads
1942 Downloads
A detail component to assist in equally distributing objects across a distance (like windows or doors in a wall). |
No rating |
199 Downloads
Since I don't know how to call this, I named it Globe with Rings.
The family is full parametric. There are 2 layers of rings, wich you can control the diameter plus the with and height of each layer.
And you can change the materials of the Outer Ring, the Inner Ring, the Core Sphere and the Stakes separately.
The Core Sphere equal to 1/5 from the inner ring.
Hope you enjoy it! |
2733 Downloads
Parametric detail item that i use in construction drawings when an existing wall has been cut. May be of some use.
(Revit 2014) |
No rating |
545 Downloads
Tile surround and light source for realistic renderings |
3200 Downloads
2337 Downloads
150W x 70D x 75H cmTable Top ( SF 3152 )Metalic Ash Gray LegsHanging Metal CPU Rack at both side |
4867 Downloads
Reward this to your favorite coworkers when they do something right in Revit! Not Parametric, not even finished. Just for fun! |
1729 Downloads
1788 Downloads
This is a standard keg for drinking beer |
2207 Downloads
