Product Version: Unknown
780 Downloads
9 foot column. material can be edited.. rate guys! and girls! |
18657 Downloads
4 poles straight |
No rating |
626 Downloads
Its a rough draft of the base, the capital of the column is still needed. This is because each column has a different capital design. |
441 Downloads
Flawless |
9466 Downloads
This is a 3D Family of Circular Mushroom Column. All constraints are editable. |
No rating |
Product Version: Revit Architecture 2019
635 Downloads
No rating |
292 Downloads
530 Downloads
Parametric: you can change height (adjust to levels) and materials |
6615 Downloads
Parametric Tuscan order classical column with entasis. Based on the proportions of the classical orders. Only requires the lower shaft diameter to be sized accurately. |
3913 Downloads
Black |
7695 Downloads
Parametric |
4787 Downloads
Column with grooves that adjust with height. |
28510 Downloads
Column |
Product Version: Revit Building 5.1
13532 Downloads
my first design object |
6451 Downloads
Parametric Shaft and Base. Capital is nested and unparametric. Created for Oklahoma State Capitol. |
10235 Downloads
coluna arquitetonica |
1394 Downloads
cool column |
No rating |
4887 Downloads
Corinthian Column |
No rating |
8161 Downloads
Corinthian Column |
No rating |
10839 Downloads
Corinthian Column |
6551 Downloads
Proportions based on Vignola. To change height, change the type parameter.
Thanks to Domokur Architects for the tutorial.
http://domokurarchitects.blogspot.com/2013/01/revit-tip-scalable-model-family.html |
3877 Downloads
Here it is folks, a Corinthian Column based on the one available here on RevitCity for so many years. But this one acts just like normal columns, with Base and Top level parameters to define the height, and the column itself scales properly based on that height.
Thanks to this blog post on how to make this work: http://domokurarchitects.blogspot.com/2013/01/revit-tip-scalable-model-family.html |
12109 Downloads
Column with Parametric Height and Material.
Note: The column isn't two-toned, it's just the lighting in the image. |
No rating |
5848 Downloads
Doric Column |
8060 Downloads
Doric Column |
5085 Downloads
Doric Column |
4492 Downloads
My first family shared on this site. I looked at the Classic Doric column posted here for help. There were a few things I didn't like about that one, so I built this one from scratch. The parameters break if you go too small with it (I think at like 3' tall) but other than that it seems to proportion perfectly. I may build one with a typical Doric base at some point or if anyone wants to modify it feel free. Just make sure to share it if you do. Thanks.
I apologize for the large image, I assumed it would be resized. |
11950 Downloads
Doric Temple with 4x6 column grid based on the Doric column uploaded by SS22 on 30th May 2014: https://www.revitcity.com/downloads.php?action=view&object_id=15365
Unfortunately, it works only in Revit 2019 and newer versions. |
No rating |
1215 Downloads
Exterior Archway w/ Columns (parametric) |
19650 Downloads
