hope you enjoy it |
Product Version: Unknown
12919 Downloads
6929 Downloads
7 inch fluted |
Product Version: Revit Building 5.1
3643 Downloads
Fypon Pilaster |
6541 Downloads
9 Inch Pilaster Fluted |
5784 Downloads
Architectural Columns 300mm Diameter |
Product Version: Revit Structure 2018
4720 Downloads
Scaleable Bracket Scroll |
3774 Downloads
SImple Clux Cloister Column for Fordham Medieval Studies Projects. |
1090 Downloads
Column architectural Greek 500mm diameter circular |
No rating |
2234 Downloads
Corner Pilaster |
No rating |
6196 Downloads
Rectangular wall-hosted pilaster with pyramidal base and head. Sizes can be edited through parameters in properties. |
5176 Downloads
Fluted Pilaster w/ adjustable Height, Width, and Wall Projection. If you're family savvy you can add parameters for top and base adjustments. Two material controls. |
No rating |
1727 Downloads
Mediterranean Columns, Height and Base parametric. |
17850 Downloads
No rating |
11041 Downloads
No rating |
Product Version: Revit MEP 2010
2879 Downloads
It can be used for any dicipline |
No rating |
2426 Downloads
No rating |
1918 Downloads
1833 Downloads
Parametric pediment with control for
- Width
- pediment angle
- Materials
- Face based
Sugestion and comment welcome |
No rating |
4424 Downloads
Product Version: Revit Building 9
3022 Downloads
Pilaster |
No rating |
7491 Downloads
Parametric Shaft and Base. Capital is nested and unparametric. Created for Oklahoma State Capitol. |
No rating |
4986 Downloads
No rating |
5001 Downloads
wall hosted pilaster with bumpout architectural column family type based make bumpout small eg 5mm to simplify to rectangle http://www.vtourinteractive.com/blog |
No rating |
2985 Downloads
Porch Column |
4010 Downloads
Creation of the modern column |
No rating |
2142 Downloads
