59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
6ft by 3ft Mirror w/ wood trim
wall based 6ft wide by 3ft high mirror designed for public bathrooms. Default 4ft above floor.
3 Stars from 5 Votes
Product Version: Unknown
38130 Downloads
Base Cabinet - Acid Cabinet - Wall Mounted
Base Cabinet - Acid Cabinet - Wall Mounted - Lab
4.5 Stars from 5 Votes
Product Version: Revit Building 5.1
11199 Downloads
Bench Top - 3 Square holes
Bench top to match standard International Metric Library bench top's.
3 square sink holes, all sink widths and lengths will remain the same when one is adjusted
This was put together rather roughly for my project so may not be perfect...
2484 Downloads
Child Sink Casework
Normal Casework at a lower height
2574 Downloads
Counter Top w Sink Hole.rfa
1 Stars from 1 Votes
2637 Downloads
Countertop - 2D
Countertop - 2D
elevation and plan
965 Downloads
Countertop - 3D
Countertop - 3D
wall mounted
5320 Downloads
Countertop - Straight w/ adj splashes
Countertop straight with instance length and adjustable backspash dimensions and visability
3.5 Stars from 4 Votes
4493 Downloads
Daycare Diaper Change Station
Daycare Diaper Change Station with 12 bins below in base cabinet and twelve slots above in wall cabinet.
3517 Downloads
Opal Caroma 720 Basin
Left hand shelf basin, not wall hosted, no tap. First upload aswell! Thanks.
http://www.caroma.com.au/bathrooms/basins/opal/opal-720-wall-basin-left-hand-shelf -- to see the product.
2280 Downloads
OSCA Shaving Cabinet 1200mm
Basic Mirrored Shaving Cabinet. Vanity or medicine cabinet.
1200 x 720 x 150.
Bevelled edges.
Available from Highgrove Bathrooms in Australia.
5 Stars from 2 Votes
3667 Downloads
Parametric Toilet Compartment
A simply modeled but very thoroughly parametricized toilet compartment. Through manipulating heights of the structural elements can be made floor or ceiling mounted. Had a little trouble with the door swing (goes all the way around when the door swings inward) so I included a toggle to turn it off - you'll have to add your own 2D line if you need it. If someone wants to fix it, I'd be grateful!
3226 Downloads
Parametric Wooden Deck
Parametric Wooden Deck Corrected version
6061 Downloads
Sink Apron
Sink Apron
ADA Compliant Under counter Sink Apron 3 foot
1 Stars from 2 Votes
3221 Downloads
Toilet room countertop w 2 round sinks
32926 Downloads
TR Countertop w sink
Toilet room counter top with single round sink.
4 Stars from 4 Votes
96345 Downloads
Vanity Counter Top w/ 3 Round Sink Holes
Standard counter top modified to allow for 3 sinks.  Outer sinks fixed to a distance from edges and middle sink is fixed to the centerline of counter top so that it stays centered upon length.  One of my first attempts at customizing, but it appears to work well.
3342 Downloads
Page 1 of 1 |
Page generation time: 0.4128
