68 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
Adjustable Skylights in a Common Frame- 4x4 Unit
This family is based off of the Plastico Pyramid Skylights that are for larger opening spans.  This is similar to my other family, but this one will only have 4 skylights. It's a modular system with adjustable skylight size with a set minimum 17.25" width and 99" max length for individual units.  The mullion, curb depth, curb height, frame height, and pyramid heights are all adjustable.  I have created another family for 2x2 units (4 skylights total) that is parametric also.
15188 Downloads
Barrel Vault Skylight
4 Stars from 4 Votes
Product Version: Unknown
15916 Downloads
ciralight suntracker
solar powered rotational gps skylight
2113 Downloads
Domed Skylight
Domed Skylight
Parametric domed skylight. Modelled for symbolic use in one of our projects, so not fully detailed out.
7340 Downloads
finestra con profilo esterno
Product Version: Revit Building 9
890 Downloads
Fixed 2x3 skylight
Fixed 2x3 skylight
skylight, 2x3 fixed, with wood trim
3 Stars from 5 Votes
6095 Downloads
Fixed Skylight
Fixed Skylight
Fixed Skylight
Product Version: Revit Building 5.1
12761 Downloads
Generic Skylight Component
Skylight that cuts properly in section, but must be inserted as a GENERIC component. Whew.
3.5 Stars from 5 Votes
20636 Downloads
Multiple Pyramid Skylights in a Common Frame
This family is based off of the Plastico Pyramid Skylights that are for larger opening spans.  It's a modular system with adjustable skylight size with a set minimum 17.25" width and 99" max length for individual units.  The number of units length and width is adjustable to as large as needed to no smaller than 3x3. The mullion, curb depth, curb height, frame height, and pyramid heights are all adjustable.  This family requires at least 3 unit by 3 unit setup, otherwise it won't look right.  I have created another family for 2x2 units (4 skylights total) that is parametric also.
5 Stars from 2 Votes
5147 Downloads
Multiple Pyramid Skylights in a Common Frame 1x any amount of units
3 Stars from 2 Votes
7477 Downloads
Multiple Pyramid Skylights in a Common Frame 2x any amount of units
This family is based off of the Plastico Pyramid Skylights that are for larger opening spans.  This is similar to my other family, but this one can be 2 units wide and an infinite number long. It's a modular system with adjustable skylight size with a set minimum 17.25" width and 99" max length for individual units.  The mullion, curb depth, curb height, frame height, and pyramid heights are all adjustable.
4471 Downloads
Operable Skylight
Operable Skylight
Operable Skylight
11146 Downloads
Pyramid Skylight
Pyramid Skylight
Pyramid glass Skylight, uses the same parametric Curb and Frame as my other skylight (barrel), but length doesnt have to equal width... Glass height is editable too... It could use more detail, but here it is...
4.5 Stars from 3 Votes
20695 Downloads
Roof Light Domed
Roof Light Domed
Parametric Domed Roof Light Fsmily Type
13933 Downloads
Roof window VELUX
Roof window VELUX
Basic 1140 x 1180mm centre-pivot roof window with flashing and blind set in generic 300mm roof.
This Revit family is now superseded.
Please visit www.velux.co.uk for latest BIM information
9675 Downloads
Roof window VELUX C04
550 x 980mm centre-pivot roof window with flashing and blind set in generic 300mm roof.
3.5 Stars from 3 Votes
9623 Downloads
Roof window VELUX F06
660 x 1180mm centre-pivot roof window with flashing and blind set in generic 300mm roof.
9315 Downloads
Roof window VELUX M04
780 x 980mm centre-pivot roof window with flashing and blind set in generic 300mm roof.
3 Stars from 1 Votes
7425 Downloads
Roof window VELUX M06
780 x 1180mm centre-pivot roof window with flashing and blind set in generic 300mm roof.
4 Stars from 1 Votes
6749 Downloads
Roof window VELUX M08
780 x 1400mm centre-pivot roof window with flashing and blind set in generic 300mm roof.
7184 Downloads
Roof window VELUX M08 M34 combination
780 x 1400mm top-hung roof window over 780 x 920mm fixed roof window with flashing and blind set in generic 300mm roof.
3 Stars from 4 Votes
14557 Downloads
Roof window VELUX P10
940 x 1600mm centre-pivot roof window with flashing and blind set in generic 300mm roof.
9185 Downloads
Roof window VELUX P10 P34 combination
940 x 1600mm top-hung roof window over 940 x 920mm fixed roof window with flashing and blind set in generic 300mm roof.
10134 Downloads
Roof window VELUX S06
3.5 Stars from 2 Votes
7365 Downloads
Rooflight Dome
Rooflight Dome
Surface based and parametric
4 Stars from 6 Votes
5907 Downloads
Rooflight Dome sloping
2677 Downloads
Simple adjustable skylight
Instance-adjustable dimensions, with two types preset for frame materials (wood and metal). Edit the type options to change materials.
Creates the necessary opening in the roof, and shows a very simple non-operable skylight. Doesn't have fancy construction details.
Created as a generic component, so insert into your model via components menu rather than windows menu.
25511 Downloads
Sky light roof
Sky light roof
Parametric sky light roof
11779 Downloads
skydome skylight
skydome skylight
skydome skylight rooflight roof window
4 Stars from 5 Votes
12805 Downloads
Skylight
Skylight
4733 Downloads
Page generation time: 0.6572
