72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 11 | 1 | 2 | 3 | 4 | 5 Next >>
1200 x 1800 Arched window with Sunray transum
3 Stars from 11 Votes
Product Version: Unknown
37568 Downloads
1900's Home Window
1900's Home Window
Parametric Height/Width
5 Stars from 2 Votes
7337 Downloads
3x2 Wood Transom Window
3 Stars from 1 Votes
15645 Downloads
3X5 WINDOW
3X5 WINDOW
1139 Downloads
4-Pane_Sliding_Windows_w_Double_and_Quadruple_Awning_Transom_4527.rfa
4 Stars from 5 Votes
10615 Downloads
40mm Casement window
this is a 40mm casement window modeled off the Vantage profile, all elements are extruded profiles right down to the neoprene seals, this file is quite large but excellent for showing that extra detail in your project.  I think i've managed to iron out all the kinks, and yes this window is parametric.
3.5 Stars from 7 Votes
22530 Downloads
40mm Double Casement Window - adjustable pane widths
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  One awning & one fixed pane - both panes have adjustable widths
3.5 Stars from 4 Votes
19895 Downloads
40mm Double Casement Window - even
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is parametric.  One awning & one fixed pane - even
4.5 Stars from 5 Votes
26849 Downloads
40mm fixed window
40mm fixed window
this is a fixed 40mm window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is parametric.
4.5 Stars from 2 Votes
31653 Downloads
40mm Triple Casement Window - Adjustable
this is a fixed 40mm triple casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  Two awning & one fixed pane - adjust awning window widths in element properties dialogue & this ultimately defines the fixed central pane.
3 Stars from 7 Votes
53878 Downloads
4x2 Wood Transom Window
4 Stars from 1 Votes
8757 Downloads
4x2 Wood Transom Windows
2 Stars from 7 Votes
15848 Downloads
5x2 Wood Transom Window
7101 Downloads
5x2 Wood Transom Windows
5 Stars from 3 Votes
14325 Downloads
6x2 Wood Transom Window
8272 Downloads
6x2 Wood Transom WIndows
2.5 Stars from 4 Votes
14172 Downloads
A fully parametric Window
I needed this window for my project. So I created this. Please give feedback.
4 Stars from 6 Votes
17906 Downloads
AGRV_GLAZ_Operating-A2-A1_可開窗-A2-A1
Metric Operating Windows (1fix ,1Operating) with DIM & Material parameters and dimension Guide
Use parameter setting to switch between Casement Awning Hopper
Visit our website AgileRevit.com for more families
853 Downloads
AGRV_GLAZ_Operating-A2-A2_可開窗-A2-A2
1013 Downloads
AGRV_GLAZ_Operating-B1-AB1_可開窗-B1-AB1
Metric Operating Windows (2Operating) with DIM & Material parameters and dimension Guide
608 Downloads
AGRV_GLAZ_Operating-B1_可開窗-B1
654 Downloads
AGRV_GLAZ_Operating-B2-A1-a_可開窗-B2-A1-curse
AGRV_GLAZ_Operating-B2-A1-a_可開窗-B2-A1-a
Metric Operating Windows (2Fix, 1Operating) with DIM & Material parameters and dimension Guide
414 Downloads
AGRV_GLAZ_Operating-B2-A1-b_可開窗-B2-A1-b
461 Downloads
AGRV_GLAZ_Operating-B2-A1-c_可開窗-B2-A1-c
Metric Operating Windows (2Fix ,1Operating) with DIM & Material parameters and dimension Guide
Product Version: Revit Structure 2018
383 Downloads
AGRV_GLAZ_Operating-B2-A1_可開窗-B2-A1
Metric Operating Windows (3Fix, 1Operating) with DIM & Material parameters and dimension Guide
483 Downloads
AGRV_GLAZ_Operating-B2-A2-a_可開窗-B2-A2-a_
427 Downloads
AGRV_GLAZ_Operating-B2-A2-b_可開窗-B2-A2-b
543 Downloads
AGRV_GLAZ_Operating-B2-A2_可開窗-B2-A2
560 Downloads
AGRV_GLAZ_Operating-C1-AB1_可開窗-C1-AB1
Metric Operating Windows (1Fix, 2Operating) with DIM & Material parameters and dimension Guide
1030 Downloads
AGRV_GLAZ_Operating-C1-ABC1_可開窗-C1-ABC1
Metric Operating Windows (3Operating) with DIM & Material parameters and dimension Guide
1417 Downloads
Page generation time: 3.8184
