54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
1X6 window trim
1X6 window trim
1X6 window trim
Product Version: Unknown
5223 Downloads
4 window
Product Version: Revit Building 9
1427 Downloads
7 inch window crosshead
3028 Downloads
Abertura de Vão Paramétrica
Abertura de Vão Paramétrica com Mármore Bege Bahia como Moldura
5 Stars from 3 Votes
5704 Downloads
Arched Shutter - Boarded (Parametric, Wall Based)
Parametric Arched Shutter - Boarded (wallbased) Controls:
  • Window width x height x drop
  • # of boards, board spacing
  • Cross boards spacing, middle cross-board
2.5 Stars from 3 Votes
1550 Downloads
Awning for windows or doors (Toldo Ventanas o Puertas)
Toldo para Ventanas o puertas.
3 Stars from 6 Votes
7751 Downloads
dome awning
dome awning
789 Downloads
dome awning
dome awning
504 Downloads
Exterior Precast Window Sill
A commercial precast window sill that FINALLY cuts the wall correctly, unlike typical wall sweeps, and that can be used in both window families and projects
4 Stars from 5 Votes
11994 Downloads
Fenster Rolladen (shutters)
Parametric "openning" Shutters.
Variable height, width, depth, angle
4.5 Stars from 4 Votes
6644 Downloads
Glass Spider Connector Double
Steel anchoring fixture for glass panels in walls or railings
Product Version: Revit Building 9.1
5513 Downloads
Glass Spider Connector Quad
6203 Downloads
Granite Frame
Granite Frame
Granite Frame 100% Paramétric...
4.5 Stars from 3 Votes
4077 Downloads
Groundworks Horizontal Trellis
Horizontal trellis for external facade. Fully Parametric.
4 Stars from 2 Votes
8537 Downloads
Groundworks Vertical Louver
Vertical Louver for external facade. Fully Parametric.
17303 Downloads
Interior Casing_Colonial
This is a Parametric Face Based interior window casing using a standard 2 1/2" colonial profile. The sill and apron visibility can be toggled off to use as a door casing. It does not move with windows/doors so it will need to be reset if you move you move them.
315 Downloads
Interior Casing_Windsor One GR
This is a parametric face based interior window/door casing based on Windsor One Greek Revival series profiles. It's a bit of a high end look. It does not move with windows/doors so it will need to be rest if you move them.
Product Version: Revit Architecture 2019
434 Downloads
Kolbe Ultra Series Casing and Sill Assembly
Go to www.kolbe-kolbe.com for more information on our Ultra Series Casing and Sill Assembly.
821 Downloads
Louver Frame
Louver Frame
Window louver frame fixed onto the wall face.
1421 Downloads
Louvered Window SriLanka _ By Duminda Sir
Designed by ; Duminda Sir
Drawn by ; Mr Nalinda
Uploaded by ; CADLAB
https://cadlablogin.wixsite.com/cadlab
1074 Downloads
Marvin Window Case with Superman Symbol
Marvin Window Case with Superman Symbol - 2 types:
- 2' 7'' x 3' 7 5/8''
- 2' 9'' x 3' 7 5/8''
85 Downloads
Mini Blinds
This has a fixed number of Mini Blinds. You can control the width and the head height. Material adjusts from properties.
5 Stars from 2 Votes
2002 Downloads
oculus w/ wrought iron detail
2050 Downloads
Old danish windows
Old danish windows
3 Stars from 2 Votes
Product Version: Revit Structure 2017
8467 Downloads
Pairie Style Window
Pairie Style Window
NOHS / OCHS
1855 Downloads
Parametric Window Louvers
Hung from above supports, most often roof structure, this fully paramatric window louver keeps the harmful UV Rays off of your building. This is my first upload and one of my first parametric designs. Some of the parameters are type based and some of them are instance based. Please download to find out! Constructive Critique Comments are welcomed!
9336 Downloads
Plantation Shutter
Plantation Shutter
Plantation shutter modeled as a generic model.
Each blinds run would reappropriate with relation to the overall width and height.
Blinds depth remain the same. Maybe the next version could change the angle and depth with accordance to the spacing.
This is my first upload, so any constructive advise is very much appreciated. Enjoy
Product Version: Revit Structure 2016
1700 Downloads
point support glass spider fitting hardware
CRL (C.R. Laurence) HRF 14 BS rigid combination fastener with custom 4 point spider anchor. Can be used with varying glass sizes from 1/2" to 1 1/16" and variable system depth.
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?Productid=41982&GroupID=21214&History=39327:9307:13453:14103&ModelID=21214
9920 Downloads
point support spider fitting hardware 2012
8087 Downloads
PVC Profile - Detail Component
This is a Detail Component item, for a PVC window frame. Hope it's useful!
1397 Downloads
Page generation time: 18.0656
