64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
akrimee_pattern brick vent block
VENT BLOCK MASONRY.
ADJUST YOUR OWN PARAMETERS.
5 Stars from 3 Votes
3296 Downloads
Curved Panel Wall
Curved Panel Wall
Fully Parametric curved panel wall. Have fun.
2949 Downloads
Curved Panel Wall - Circumscribed
Inside Face of Panels is circumscribed to the radial array. Fully parametric.
Product Version: Unknown
830 Downloads
Deer Mount 5" wall
Deer Mount 5" wall
Made at NOHS, works best on 5" walls
1235 Downloads
Deer Mount 6" wall
Deer Mount 6" wall
Made at NOHS, works best on 6" walls
5 Stars from 2 Votes
3169 Downloads
Double-sided movable wall
Model of Pathfinder individual, omni-directional panel wall with storage for panels on both sides of opening. Panels are in the folded position. Changing the size of the opening will not change the number of panels. In this sense it's a generic model.
3 Stars from 4 Votes
6071 Downloads
Folding Partition. Partición plegable. Simple and highly parametric
Folding partition, unfolding percentage, with integrated closet.
Tabique plegable de puertas dobles con marco personalizable, apertura regulable en porcentaje, armario recogepaneles incorporado. Dimensiones parametrizadas tanto de armario como de taboque plegable.
16019 Downloads
Folding Partition. Partición plegable. Simple and parametric. CORREGIDO
1 Stars from 2 Votes
5908 Downloads
Inclined wall ( angled wall angle wall slanted wall tilted wall )
adjustable wall height and angle of slant
3842 Downloads
Parametric Perforated Brick Wall
Parametric Perforated Brick Wall done in Revit 2021 with changeable materials.
4 Stars from 3 Votes
8592 Downloads
Partition floor based
This is a partition with base and top trim and three panels
4.5 Stars from 2 Votes
5430 Downloads
Slatwall 8' tall
Slatwall 8' tall
An 8' tall slatwall. Height is set, length and materials are parametric. Slats are 4" apart. board is 1 5/8" thick. (according to the ones I was modeling)
3114 Downloads
Solarpanel
Solarpanel
Fully parametric objects to decorate the facade
Made by MJ-objects.dk
5422 Downloads
VIMETRA FOLDING PARTITION WALL
Fully parametrical, length, heights, size of panels, distance, ...
Muro móvil Vimetra  totalmente parametrizable
Hay una versión para muro abierto y otra para el muro cerrado (ésta)
3.5 Stars from 3 Votes
Product Version: Revit Architecture 2019
1823 Downloads
VIMETRA FOLDING PARTITION WALL open
Fully parametrical, length, heights, size of panels, dinstance, ...
3567 Downloads
Wall Panel: Leaves pattern
Versatile, and customizable. Works on a seamless pattern
13153 Downloads
Page 1 of 1 |
Page generation time: 0.4487
